Remote Starter?
Old Aug 25, 2004 | 04:24 PM
choisky's Avatar
Remote Starter?
I am going to install a remote starter on my max soon. You know, winter is coming and I dodn't like my skinny a*s out to warm up the engine. I searched for a thread regarding this topic but couldn't find one (I think). I will need just a simple starter not with all the bells and whistles and prolly will install it myself. So, what's your recommendation and is there any write-ups for wiring for a starter? I'd appreciate any input. Thanks much!
Old Aug 25, 2004 | 06:25 PM
95turbo gxe's Avatar
I installed mine my self the very first one Ive every done. Its not the easy but if you got about 3 to 4 hours it can be done. Craig brace fac info has some of the wiring info in it. Go to facts and check his site you will see it
Old Aug 25, 2004 | 07:26 PM
choisky's Avatar
Thanks, silverlinekenne! I found the info. If you can, could you kindly write up what you did with your own starter? Just briefly what starter to buy, where to start to install, and which wires to look at and stuff... My max is 89 GXE by the way. I hope starter wiring is pretty much universal. Thanks!
GO *****! (OR, TIGERS!)
Old Aug 25, 2004 | 08:34 PM
internetautomar's Avatar
mod or sell?
Depending on which unit you get some are easier to install than others, even though they all use about the same amount of wires.
and the job should only take about 2 hours to do.
at least my install only took that long initially.
just one tip, LABEL every wire and use a test light to verify everything.
I sell remote starters
Old Aug 26, 2004 | 12:18 AM
lophix's Avatar
i think 2hrs is an underestimate...at least for someone who might be uncomfortable working with wires and the possibility of screwing something up. I suggest you read the manual over and over, till you're very comfortable. You dont want to have to go back in there later on, so test before soldering the wires...or use quick disconnects / t-taps. I installed a viper unit in mine and it took me about 6 hrs (doing a whole lot of other stuff as well)...plus you want the wiring neat, so don;t rush it.
Btw, as you've probably seen on Craig's page, there's a neutral safety wire, if you're 5-spd...use it
Old Aug 26, 2004 | 06:13 AM
mod or sell?
:dunno: a remote start by itself , no alram no keyless, is a fairly straight forward install.
but as I said label all the wires in the kit before you get to the car, it makes things much quicker.
also don't forget that the maxima uses 2 starter wires not 1.
my install took a bit longer becase the color code was wrong on one wire, and I blew a fusible link.
and then I forgot to reconnect the harness.
so it took a bit longer than expected.
and stay away from the bulldog remote start DIY kits they're junk.
Old Aug 26, 2004 | 09:46 AM
Spipedong90's Avatar
http://forums.maxima.org/showthread.php?t=283628
2345678
Old Aug 26, 2004 | 09:58 AM
Originally Posted by Spipedong90
well 3 to 4 hours was to install the remote starter and a whole lot of other things with my alarm. Well I went with the clarion ungo. I think its the sr5000 or something. Its has everything you can think of and them some. It ran like 179.00
shipped on ebay. As far as hooking it up get a wiring layout on your car and then read the manual that comes with the starter and go from their. AS FAR AS
using a test light I would advise that as to it can blow up some **** like an air bag in your face. SO use a multi meter to check and verify your wires.
Old Aug 26, 2004 | 10:15 AM
«§»Craig B«§»'s Avatar
dont touch any wires in yellow harnesses and you'll be ok
Old Aug 26, 2004 | 10:19 AM
Hah, yeah, airbag hurts enough on arms, let alone faces.
I never knew there was something that could chafe, burn, AND bruise all at once, while simultaneously poisoning you with chemicals. Good ol' airbag.
maxima297
Sep 30, 2015 03:32 PM
msellas
Sep 23, 2015 09:16 PM
ToTheMax305
Sep 23, 2015 09:11 PM
flu2000
Sep 14, 2015 12:34 PM
intimidator
Sep 5, 2015 07:23 PM
