need info:intermittent fuel pump prob 92 SE
need info:intermittent fuel pump prob 93 SE
Have problem that comes and goes, the fuel pump quits periodically but can't seem to get a handle on why. Sometimes it just cuts out but comes back on; like on xprsway and engine restarts, other times it totally quits an takes multiple on/off with key till you hear pump restart; then engine starts again. Problem is other than extreme irritation of restarting it otherwise runs extremely well. My mechanic got an error code on the brain and replaced it but it has continued to do it. Of course I told him he should have replaced the pump but he isn't convinced that its actually the problem. So what else could it be.
It's the pump. An OEM will run $250-300. A Walbro kit is around >$100.
I replaced mine after it died one time too many (as you described), with the Walbro. It has run well for 15K miles.
Not as quiet as the stock pump but it works well. You can replace the pump in half an hour with common hand tools. Take out the bottom cushion of the rear seat, the pump is in the fuel tank, under the cover in the middle of the floor.
Fred
Fred
Originally Posted by Fosgate Fan
don't think our fuel pumps are known to go bad (correct me if i'm wrong). what condition is the fuel filter? that might be clogged if it hasn't been changed in awhile
BTW Stoken, I have a working fuel pump for sale. $35 + shipping. Less than 1000 miles of use. Let me know if you are interested.
OK, a little note its really a 93SE, thanks for the responses, I really have never had an intermittent pump other cars of mine its either run or quit. The filter's good that's something of a no brainer. The car's got 160k on it, the regulator's (in the trunk?) where...(is it the round device mounted under the rear window deck next to the speaker). Just as note, from another thread/post I took the rear seat out and looked at the sending unit wiring. I wasn't really happy about the condition of the wiring harness under the seat but could not see any really problem there.
Keep in mind I never had a single starting or stalling problem until that day so I never had a reason to check that harness prior to that day. As you can see from the pics, I cut and by-pass the burnt wire and all was well.
MIKE
jmlee44
10-02-2022 02:13 PM
06-06-2017 02:01 PM
