Camber?>>>
Old Apr 6, 2001 | 07:51 PM
Dan93se
Here's the deal. Took my car to get aligned today, camber is off -.5 in the front on both sides. Can I get some camber bolts to fix this or do I need camber kits for each side?
Old Apr 6, 2001 | 08:09 PM
Chris Gregg's Avatar
Get Off My Lawn
I have some camber bolts for sale if your interested. Honestly, I don't know how worried I'd be about it being off unless your noticing tire wear. Email though if interested, they're new in the box.
Old Apr 6, 2001 | 08:30 PM
brubenstein's Avatar
-.5 is probably better for handling, and with them both the same there should be no pulling. I would leave it alone.
Old Apr 6, 2001 | 08:38 PM
Old Apr 6, 2001 | 10:26 PM
Dan93se
tire wear
Considering I have Z-rated tires wouldn't the inside of the tires wear fairly guick, with negative camber though.
Old Apr 7, 2001 | 10:35 AM
Re: tire wear
Check the alignment specs for the car. My Stanza FSM (identical suspension) calls for -.5 - 1.0 degrees of camber. So -.5 is within spec. If you do a lot of hard cornering the negative camber will give better tire wear, because the contact patch is more even (that's why it give better handling).
Old Apr 7, 2001 | 02:46 PM
Dan93se
Re: tire wear
Thanks, for your help.I didn't check to see if that was within spec. I was just told that camber should be as close to 0 as possible.
matts95max
Apr 23, 2025 10:44 AM
JacksMax
Mar 2, 2001 02:31 PM
sachin98max
Feb 24, 2001 11:35 PM
I30CeFiRo
Dec 28, 2000 09:25 PM
ZuMBLe
Nov 1, 2000 07:39 PM
