seafoam
seafoam
which vaccum line should i use for the seafoam and where is the line located ive herd the fuel regulator line but where is that located and do i pour it in or how do i hook it up
follow the fuel rail..at the end of the rail there should be a regulator with a smaller rubber vacume line attached to it. pull that line so it is disconnected from the regulator. stick the hose in the can but regulating the flow by pinching the hose. the engine's vacume will pull the sea foam into the motor. do this on a hot engine and exercise caution. if you're unsure about the procedure refer to a professional.
heh, I just made this post like 2 days ago but deleted it because there are already seamfoam threads in the fluids section.
Check out this thread: http://forums.maxima.org/showthread.php?t=308576
Most people use the brake booster hose. I did mine yesterday using the brake booster hose... although my exhaust didn't smoke at all like everyone elses, and I sucked up over half the bottle
yes brake booster is good also...just need to regulate the flow more...or else it'll stall.
Or bend rods. I can't believe people are so willing to use this hose and at the same time go ape crap over CAIs.
yup...that's why i said to exercise caution. it's going to smoke..but you can't just pour it down. there's A LOT of vacume at the brake booster.
It was one stinkin post, and it's not like I haven't contributed to the subject before. Cripes, I made damn write up with pictures before.
edit: alot of those smilies look familiar too
If it was one post, I wouldn't have cared. But it's been more than that.
okie
Seafoam can + brake booster =
Parrrrttttttttttttyyyyy!
Decent spot on the VG:
http://s92599732.onlinehome.us/image...m/P1010024.JPG
Using brake booster because I dont thing the first spot really gets all 6 cylinders good and vice versa:
http://s92599732.onlinehome.us/image...m/P1010032.JPG
VE > VG because there are multiple Vacuum line ports that will get all of the cylinders evenly
http://s92599732.onlinehome.us/image...m/P1010028.JPG
Nothing beats just taking the intake manifold(s) off and blasting them to hell with CRC Green though
220k+ A32
Sep 23, 2015 03:38 PM
MrEous
41
Dec 5, 2005 03:50 PM
E55AMG2
Fluids and Lubricants
50
Dec 21, 2004 09:15 PM
I wouldn't recommend PW too much.
