Even another Bose Question....
Old Sep 21, 2004 | 01:33 PM
ntjoe's Avatar
It seems everyone has Bose questions today. Here we go: I just bought my 89 SE and the headunit was dead. I installed a Pioneer DEH-5 that I had from my other Max. The back amps still work but the front are shot. I have bypassed all the amps, however, and it sounds great using the stock Bose speakers. However I have since read that the speakers are 1 ohm and it might damage my HU. I was under the impression that the problem was only if the amps where being used too. I even tried searching and found nothing on this. Reason I am asking is I can't afford a set of speakers at this moment, but dont want to blow my HU.
Any ideas?
Thanks and sorry for the newbie question....
Old Sep 21, 2004 | 02:18 PM
ntjoe's Avatar
Anyone? I have searched all over the internet and on this site with no luck. Come on, someones got to know.
Old Sep 21, 2004 | 06:11 PM
internetautomar's Avatar
mod or sell?
most aftermarket head units are designed to support 4 ohm speakers.
if you lower the ohms to far down you cause damage to the HU, it may not be immediate but it will happen.
Found that out when I tried to run my car sub on my home unit, the Cap went POP! and smoke filled the room (good thing it was under warranty)
Old Sep 22, 2004 | 06:30 AM
ntjoe's Avatar
Do'H!!! Thanks for the info. I am lining up some replacements and should have them in in a couple of days.
Must resist urge to listen to stereo!
Old Sep 22, 2004 | 07:10 AM
Reizy's Avatar
First time poster. Yeah!
As for the Bose, I have the Bose in a 90 SE and did the same as you and bypassed all the stock amps but I installed a small sony amp between the HU and speakers. It has been going strong for 5 years. The amp has cut off a couple of times due to overheating but only on long road trips with excessive volume levels. And if you add a small tweeter up in the top of the door panels, they sound great. Good luck.
Old Sep 22, 2004 | 07:25 AM
ntjoe's Avatar
Not a bad idea...if I get an amp that will handle the 1 ohm speakers. The Bose speakers in the car are in great shape, and the idea of adding a tweater on the door is awesome. I'll have to look into this idea.
Thanks for the input!
Old Sep 22, 2004 | 07:40 AM
probmxstyle's Avatar
I have a set of working front BOSE amps with the speakers still in them if your interested.
Old Sep 22, 2004 | 07:45 AM
ntjoe's Avatar
Thanks for the offer, but my Bose head unit is dead. I know I can't use my Pioneer headunit with the bose amps unless I get that pricey adaptor and thats a bit more than I want to spend in total, when I can either just get a new set of speakers or get a 4-channel amp that can handle 1-ohm speakers.
Thanks! Joe
chisam14
Nov 6, 2018 08:56 PM
Fbana41
Aug 29, 2016 12:18 PM
sliptap
Sep 30, 2015 05:57 AM
Redfox
Sep 28, 2015 10:41 AM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
