slug in morning and wet
Old Oct 1, 2004 | 06:51 PM
jrodmaxima13's Avatar
got a 94 gxe with 156k on it and everyonce in a while when it is wet and a little bit cooler only does my car suck big time it hardly wants to accelerate until it hits 3000-3500 rpms then it will be fine it will do this for about 15 minutes until the motor has warmed up. i replaced plugs wire cap and rotor it still did it after plugs and wires i havent had those conditions really since cap and rotor but if it isnt that anyone have any suggestions other then that motor is butter love it just wish it wasnt so damn slow
Old Oct 1, 2004 | 07:02 PM
thumpyls's Avatar
try installing an intake or a y pipe to help ur power issues..it might be that ur o2 has a weak signal and then it gets stronger.. 75 bucks could save u the hassle
Old Oct 1, 2004 | 07:08 PM
alright thanks for the tip somebody told me cap and rotor but i will wait and see what happens with it and check out the o2 snensor
Old Oct 1, 2004 | 07:12 PM
blacks92seAuto
fuel filter clogged? i remember on my subaru, when it was cold and i had just started the car, it would be really slow up the slightest hill, then once it caught rpms it would be fine, or until it warmed up, then i replaced fuel fitler and it acceled fine all times
Old Oct 2, 2004 | 12:15 AM
already had that replaced as well not sure what else it could be i will try the o2 sensor if it keeps acting up
Old Oct 2, 2004 | 12:57 AM
Magnifico's Avatar
my guess would be cap/rotor, see how that works out for ya. if that doesnt work, just get a bottle of water and spray a LIGHT MIST around with car idling to emulate the wet conditions and to try and find a moisture problem
if its having problems on a cold engine which it sounds like dont blame the o2 sensor, but if you have money its probably a good idea to replace it anyway as a safeguard for your gas mileage if you dont know how old it is since you just got the car
Old Oct 2, 2004 | 02:50 PM
josequervo's Avatar
i had the same problem with my 90 it tunred out to be the injector was severly clogged had it replaced at a little over 100$ canadian hope this may help
Old Oct 2, 2004 | 03:03 PM
hope thats not it my uncle had 4 out of the 6 injectors changed at some point before he gave it to me he bought it used in 96 then gave it to me in december of 03 put over 20,0000 miles since then
Miket2006
Mar 1, 2021 03:55 AM
mclasser
22
Nov 12, 2020 01:58 PM
gigabyte
Jan 6, 2017 06:05 PM
mpbclutch33
Dec 26, 2015 11:11 AM
markevans999
Sep 10, 2015 04:29 PM
