installing an FSTB
Old Sep 27, 2000 | 11:25 AM
sTAE's Avatar
I should be getting my FSTB today. (my very first mod)
I'm a really newbie at all of this...could I install it myself? and how can I be sure that I did it right? or is it a no brainer install?
Old Sep 27, 2000 | 08:11 PM
«§»Craig B«§»'s Avatar
it's simple
just remove 3 bolts from each strut tower, put the bar on, and replace the bolts
Old Sep 27, 2000 | 08:13 PM
James92SE's Avatar
2 VE's are better than one!
no brainer. just unbolt the three nuts at the top of each strut. line up the strut bar, lay it on there and bolt away.
Old Sep 27, 2000 | 08:50 PM
andy90se5spd's Avatar
here you go...
tools:
14mm socket wrench
adjustable crescent wrench
torque wrench
the car was flat on the ground when I did the installation.
1. use 14mm wrench, remove the 6 strut tower nuts
2. do a preliminary adjustment for width. twist the ring braces (the C shaped ends that go on the strut tower bolts) to adjust the width
3. on one side (I did passenger side first), put a ring brace onto the bolts and screw the nuts on to hold it in place but don’t tighten completely
4. go to the other side and make final width adjustment with the ring brace so it can fit over the bolts . screw nuts on but don’t tighten completely
5. make sure the bends of the FSTB are towards the top. use adjustable crescent wrench, tighten centering nuts on each end against the brace itself
6. use the torque wrench and torque the 6 strut tower nuts to 35 ft-lbs
7. use adjustable crescent wrench to tighten nut on bolt that connects strut tower brace to the ring braces
done!
good luck
andy
Old Sep 28, 2000 | 06:25 AM
sTAE's Avatar
Re: here you go...
Hey thanks for the detailed instructions, Andy. I really appreciate it.
As I'm sure anyone else would, I wanted to be sure that I do it right the first time.
Thanks again.
Old Sep 28, 2000 | 04:23 PM
Canuck's Avatar
Make sure that the car is on a level surface.
MaxLife17
Jun 27, 2019 01:37 PM
Excalibur23
Oct 13, 2015 04:33 PM
Max8
Sep 22, 2015 02:53 PM
2kmaximel
Sep 16, 2015 03:19 PM
Johnny9595
Sep 3, 2015 05:18 AM
