vtc
Old Nov 2, 2004 | 02:14 PM
Jeff583's Avatar
vtc
where the hell is the rewiring the VTC mod at
Old Nov 2, 2004 | 02:15 PM
Mizeree_X's Avatar
Getting back to his roots
Paypal me $2 and I'll tell you.
Old Nov 2, 2004 | 02:16 PM
Jeff92se's Avatar
I'm needing a caw
I'll tell you for $1
Mizeree_X's Avatar
$0.99 and the answer's yours!!
Old Nov 2, 2004 | 02:17 PM
Jeff92se's Avatar
I'm needing a caw
75 cents and that's my final offer
Old Nov 2, 2004 | 02:19 PM
alpicone's Avatar
All that long hard research and your gonna sell yourself for so cheap. Its worth at least $100
Mizeree_X's Avatar
You win.....I'm in the red below $0.75
Old Nov 2, 2004 | 02:22 PM
Jeff92se's Avatar
I'm needing a caw
BTW. How do you like the brakes? Haven't heard anything from ya on this for a bit.
Old Nov 2, 2004 | 02:28 PM
Mizeree_X's Avatar
Brakes are great, although I f*cked up and didn't clean them too well after I sanded the paint off of the pad contact area, so I think I'm gonna need the rotors turned prematurely. Oh well, lesson learned. Stopping power is excellent though. Slight dive to the front compared to stock, but nothing too bad and I'm guessing it's due to the fact that the Z32 calipers grab so damn well. Thanks.
One thing I thought of though, I guess some 4th gen guy had custom 2-piece rotors made for him and said the same company made custom 1-piece rotors, so maybe if someone was looking for some high-quality rotors they could have a set of Cobra rotors made with mounting holes cut in Maxima dimensions. Just a thought. Then you wouldn't need the hubcentric rings (I guess Candiman is having trouble getting more??).
Old Nov 2, 2004 | 02:29 PM
Greeny's Avatar
¯\(°_o)/¯
http://forums.maxima.org/showthread.php?t=126113 I will put it on your account
Old Nov 2, 2004 | 02:31 PM
Harvs94max's Avatar
yeah how are those breaks see a couple of poeple with the big break conversions and havent really herd much feedback about them
jeff583 check craig braces site he has a link to the "how to"
Old Nov 2, 2004 | 02:33 PM
Jeff92se's Avatar
I'm needing a caw
I don't see why you need to have the rotors turned. Are they warped? I didn't sand them but I tried not to get alot of overspray on it either.
Only person I know running 2-pc is Turbo95. But his site says he's using 2-pc rotors that are for the 3000GT. So he must be using different brackets. You can't use mine with those smaller rotors. The guy with the custom 1 pc just had the rotor redrilled to a maxima lug size. Not quite sure if that would elminate the need for a ring or not. Unless you had the holes machine pretty close to the lug size. Ie.. closer tolerance than what the stock rotor lug holes are drilled to. IMHO
Old Nov 2, 2004 | 02:34 PM
Jeff92se's Avatar
I'm needing a caw
Front and rear bbk hauls my car down big time. 13" rotor, 4 piston caliper. Can't beat that.
Matt93SE
Apr 8, 2018 09:23 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
bill99gxe
May 28, 2001 04:45 PM
trbo
May 17, 2001 09:25 AM
JonnyMax
Jan 25, 2001 08:58 AM
