put the speedo where it should be!
Old Dec 7, 2004 | 09:42 PM
Bill Brasky's Avatar
Seperated at Birth?
I just thought of this.. who knows if it's been asked before
I could care less about the speedo. i want to see the tach in all it's glory, not on the side, but in the middle like this...
http://www.stolemyinter.net/upload/Dashflip%20copy.jpg
now, i know you'd have to rewire the panel in the back, but could you effectively cut out the traces from the plug socket to the speedo and replace it with wire? you'd do the same with the tach?
it looks really good, but would it be worth the trouble?
Old Dec 7, 2004 | 11:12 PM
Maximan190's Avatar
interesting.... but the tach and speed gauges are different diameters so theres the physical issue
Old Dec 7, 2004 | 11:26 PM
Seperated at Birth?
that can be arranged. both dials are the same size IIRC w/o the bezel.
Old Dec 8, 2004 | 06:48 AM
mtcookson's Avatar
be sure to change the stepping motor as well. there could be a chance that they are different (most likely not) but just to make sure everything would work properly. after that all you'd have to do is change the wires around which should be pretty easy as you can follow the leads on the green thing to the wiring harness and swap the correct ones.
definitely an awesome idea though. i have some spare gauges laying around and can mess with that tonight possibly.
Old Dec 8, 2004 | 06:50 AM
DanNY's Avatar
Ad·min·is·tra·tor
are you that lazy to look 2 inches to the right?...or do you just want it for the looks?
Old Dec 8, 2004 | 07:54 AM
internetautomar's Avatar
mod or sell?
that's a center mounted speedo
Old Dec 8, 2004 | 10:25 AM
Seperated at Birth?
I test drove an EVO and it's got a center-mounted tach. I freaking loved it.
Old Dec 8, 2004 | 10:37 AM
DanNY's Avatar
Ad·min·is·tra·tor
hmmm might be easier to make pods and mount aftermarket gauges in it than redo the gauges in the stock housing. the screws that holds the gauge in the pod goes thought the circuit board on the back. i believe the screws are the pieces that makes the contacts to get the gauge working. getting around that will not be fun.
Old Dec 10, 2004 | 03:05 PM
Jeff92se's Avatar
I'm needing a caw
If someone posts pics again away from OT, they will get a ban. I don't have time for this crap
Old Dec 10, 2004 | 03:09 PM
MrGone's Avatar
(kind of deleted alot of posts there :-/ )
the tach is smaller than the speedo
wiring wont be too hard, IMHO
assuming you can mount them in the same spots and not have to worry about one poking out or one not sitting flush, you can bolt them like stock, but you will need to cut/move/etc the connectors on the back so the signals dont get mixed up.
Old Dec 10, 2004 | 05:15 PM
Maxima-4DSC's Avatar
YoU CaNt SeE mE
bad day today jeff ?
Old Dec 10, 2004 | 09:20 PM
mtcookson's Avatar
i think that picture was just a little over doing it...
i haven't been able to find my gosh dang gauges so i've not been able to work on them yet. once i do i'll let you guys know how it works out unless someone beats me to it.
MR2 T'd
Jul 9, 2021 05:06 AM
mvm062
Nov 30, 2020 09:00 AM
Fbana41
Aug 29, 2016 12:18 PM
220k+ A32
Sep 23, 2015 03:38 PM
Justin Kroll
Sep 2, 2015 11:06 AM
