While I'm at it..another issue I'm having
Old Dec 21, 2004 | 08:53 AM
GO_VOLS!'s Avatar
It's in the 20s on my way to and from work lately. My car won't reach normal operating temp unless I'm sitting at a stop light for an extended period of time. It's only getting 1/4 - 1/2 of the way up to the normal operating temp. I had the coolant completely flushed over a year ago and it is to spec. The lines aren't frozen or anything. What gives?
Old Dec 21, 2004 | 08:56 AM
HTPerformance's Avatar
Perhaps your thermostat is stuck in the open position... try changing it.
Brian
Old Dec 21, 2004 | 08:58 AM
Wiking's Avatar
Read through the forum, all feel cold now...
MAXIMA IS A HOT CAR!
http://forums.maxima.org/showthread....=1#post3499240
http://forums.maxima.org/showthread.php?t=361759
http://forums.maxima.org/showthread.php?t=362106
http://forums.maxima.org/showthread.php?t=363118
http://forums.maxima.org/showthread.php?t=360258
Old Dec 21, 2004 | 10:20 AM
GO_VOLS!'s Avatar
So, where is the thing located? Do I need to take my belts off to replace this beotch?
Old Dec 21, 2004 | 10:46 AM
Wiking's Avatar
You're quite near.
Chilton has a very bad pic, section 3-15, on VG30E... Directly above water pump. Just open thermostat housing.
I Dunno if thats true...
Old Dec 21, 2004 | 11:47 AM
GO_VOLS!'s Avatar
So, when I'm changing the theromostat, I'm I going to have to drain my coolant?
Old Dec 21, 2004 | 11:50 AM
coreyblade's Avatar
CHanging the thermostat in a VG30e motor is the biggest pain in the a$$ I have ever seen!! Its f-ing horrible mate. You will have to take ALOT of stuff out to get to it including distributor, all kinds of hoses and sensors, wires, and also the bolts are on there pretty dang tight! so have some special tools with you. Good luck I spent over 3 hours changing mine last night
Old Dec 21, 2004 | 02:49 PM
goon9's Avatar
There is no need to take out any sensors nor the distributer. But it's doable with enough confidence. Just go slow and don't over react. Pick up a haynes at a parts store. You only need a few wrenchs and sockets, and a 2" socket extension. These are NOT special tools. Their the basics.
Beats the hell outta a $300 garage deal.
BTW, Corey I hav't forgot how much you suck. + fix ur profile, cuz your only 17, not 24!
Mar 12, 2020 12:06 AM
conansriver
Nov 18, 2015 02:46 PM
wingnut2006
Sep 19, 2015 06:13 AM
BrandonCause
Sep 14, 2015 10:41 PM
Mikes14Max
Advance Paint and Body Work
Sep 14, 2015 05:28 PM
