Replacement of Oil Pan Gasket
Old Jan 1, 2005 | 10:40 AM
majordan's Avatar
Has anybody this job before on the VG30E? Any problems I should be aware
of before I begin. If I decide to pay for a shop's labor, how much money should I expect to pay?
jay
Old Jan 1, 2005 | 10:48 AM
Jeff92se's Avatar
I'm needing a caw
http://www.autozone.com/servlet/UiBr...3d801f48df.jsp
Old Jan 1, 2005 | 04:05 PM
internetautomar's Avatar
mod or sell?
I know rrrfoma has done it before, but i think he's in chicago still
Old Jan 2, 2005 | 03:29 PM
mtcookson's Avatar
http://www.permatex.com/products/pro...&item_no=33694
Old Jan 2, 2005 | 07:19 PM
seth93se's Avatar
yes sir. that stuff is the greatest of all.
Old Jan 2, 2005 | 08:52 PM
DanNY's Avatar
Ad·min·is·tra·tor
it sucks in the can...after one use the can gets clogged and that's it.
with the tube you have a fighting chance.
Old Jan 2, 2005 | 09:32 PM
avmaldo's Avatar
i have done it myself. it took me about six hours with two motor mount replacements added in and a snack. it's not very hard just takes time, removing crossmember, old gasket sealent etc...
Old Jan 3, 2005 | 07:58 AM
majordan's Avatar
Zoltan,
6 Hours huh, not bad.
A couple of questions for ya....
Do you recommend the black permatex gasket maker, I thought I would need to purchase a gasket?
How did you know your motor mounts were bad? and how much did you pay for them?
Lastly, I am assuming I will need to support the engine somehow, while I do the work....will using a lift be better and how should I go about supporting the engine? Did you get a quote from a shop before you decided to do the job yourself? and if so what was his price?
tks much
jay
Old Jan 3, 2005 | 08:21 AM
DanNY's Avatar
Ad·min·is·tra·tor
Originally Posted by majordan
Zoltan,
tks much
jay
in OEM set up it's just RTV/gasket maker. there's no actual OEM oil pan gasket...(unless they updated their stock). there is 2 seals that are on the sides that you really should replace...otherwise it's just RTV.
engine mount going bad...take it out and see if the rubber is cracked/broken/separated. if yes then it's time for a new mount.
you can support it at the crank and at the tranny...best thing to use is the transverse engine support brace. it's connected to the strut towers and has a portion in the middle to support the engine.
Old Jan 3, 2005 | 09:55 AM
avmaldo's Avatar
i didn't get a quote from a shop, i just did it.
i used the ultra black in the tube, it takes 24 hrs to fully cure though.
The gaskets are two little rubber pieces on the rounded parts of the seal.
i just support the engine with a block of wood inbetween my jack and the tranny case. just be carefull.
my motor mounts looked like this.
PH98I30
Jan 9, 2025 08:08 AM
Matt93SE
Apr 8, 2018 09:23 AM
iflexsteel
Sep 15, 2015 03:37 AM
MAXSE5SPD
Aug 23, 2015 12:06 PM
maxima297
Aug 3, 2015 12:50 PM
