Getting some white lights for the Max
Old Apr 23, 2001 | 12:56 PM
adamlacey's Avatar
Already got the hiper whites headlight bulbs, but looks kinda funny w/out hiper white corner bulbs.....
Anyone know where I can get those bulbs?? I think they are # 1183 or something...
Also, looking to put white bulbs in all the interior -- anyone know the number or where to get?? (like a website)
Thanks fellas
Old Apr 23, 2001 | 01:04 PM
Jon91SE's Avatar
Pusssseeeehhhh
What brand are those headlights? If they are over stock wattage and you are not running a wiring harness, be prepared to have your sockets burn out in the future.........
Old Apr 23, 2001 | 07:13 PM
FFxI30's Avatar
Sorry its long but hope it helps
DCMax and I just did this same thing on ours. We both got PIAA's and wanted our corners to match. After looking around it seems that most people here recommend the Polarg lights. I visited the PIAA web site and saw that they make the 1157's (the corner bulb size) but I can't find them anywhere. I really like the way the Polargs look. There also is another bulb in the corners (194 wedges). These should also be replaced with either Polarg or PIAA's to get all the lights to look the same. But you wont be able to tell unless you have clear corners.
We also managed to get our bulbs in backwards and it keeps them bright all the time, instead of just when you turn on your turn signal. I haven’t talked to anyone about this, and I am curious if any one else has done this. It does seem to put off a lot of heat and I don't know if it will melt the harness. If you put the Polargs in the right way there is no problem and they look great. Anyone done this with their corners?????? I dont wanna mess something up. I am new at this so one of you Max Veterans let me know if I am screwing up or if what I have done is all right.
The answer to your question, adamlacey, is go to http://www.autofreak.net/ to order your bulbs. This is a place that we found was quick with their shipping and seemed to have what I was looking for.
Old Apr 24, 2001 | 06:22 AM
adamlacey's Avatar
alrighty... 1157
Hey thanks a lot man, but exactly which 1157 bulb did u get, there are few different wattage 1157 hyper white bulbs....
which one did u use??
And also... does anyone know interior bulb numbers and where to get them?? My dome light is out, and I might as well go hyper white with everything in the interior...
Thanks!
Old Apr 24, 2001 | 09:41 AM
FFxI30's Avatar
If you are ordering from autofreak.net the item number I purchased for the dome lights was M16. You get two of them in the package, so one you can have as a back-up or find someone to split it with ya. For the 1157's we purchased the 21/5w, their item number is M14. We chose the lowest wattage because we didnt want to worry about our wires melting from too much heat, and they look just fine. Hope this answers your questions.
Old Apr 24, 2001 | 04:39 PM
SilverBullet98's Avatar
I tried to order from them, but I couldnt find any way to checkout....any other good places to buy bulbs ??
Old Apr 24, 2001 | 08:08 PM
DCmax's Avatar
Look again, ive never had a problem
http://www.autofreak.net/lightf.html
After you click on what you want, you can hit continue shopping, and then it will give you the option of checking out.
Good Luck
Old Apr 24, 2001 | 08:12 PM
FFxI30's Avatar
I had a problem ordering from them too. I had to have DCMax order them for me. We have different Internet services, and I guess mine just didn't want to work.
wellz
Aug 26, 2015 09:05 PM
spidgeon
Aug 18, 2015 05:46 AM
Viralkill
Aug 17, 2015 10:54 AM
Viralkill
Aug 16, 2015 05:09 PM
Balkins
Aug 12, 2015 06:39 AM
