Flooded car
Old Jan 15, 2005 | 09:35 PM
minmaster1's Avatar
Flooded car
Hey guys,
i was driving today, and i ran into a bit of a problem. I tried to cross a small river, but then it dropped off and i soaked my interior, and my engine stalled. I opened the air intake box, and water poored out of it. When i try to start the engine, it cranks a turn, then stops. what should i do???
Old Jan 15, 2005 | 11:44 PM
disgruntled's Avatar
save up alot of cash, seriously dude, once your engine sucks in water through the nose....
Old Jan 16, 2005 | 12:58 AM
Jeff92se's Avatar
I'm needing a caw
Remove all sparkplugs. Crank engine. Note the Biagio water show until water stops flying out of the plug holes. Put plugs back in. Pray to the god or gods of your choice and start the car.
Old Jan 16, 2005 | 03:50 AM
Wiking's Avatar
Originally Posted by minmaster1
Hey guys,
- stop watching telly stuntmen...
- drip 'n dry
- buy boat for next river crossings
As already told, make sure u did not brake u engine block: plugs off and compression tests... If ok, proceed. If not, buy new block 500$.
Next is to dry all micropools: there are hundreds of locations where water seeps in and makes short circuit. ECU inputs short, ECU goes berserk. Water will not go out without opening those connectors, sensors etc, blasting dry...
To get an impression of the boat u drive, peek: http://www.cardomain.com/memberpage/748507/14
Old Jan 16, 2005 | 05:35 AM
internetautomar's Avatar
mod or sell?
hydrolock =
Old Jan 16, 2005 | 06:06 AM
HTPerformance's Avatar
did you have 33" tires and a lift kit??? try a snorkel next time....
Old Jan 16, 2005 | 06:43 AM
Wiking's Avatar
Originally Posted by Jeff92se
... Pray to the god or gods of your choice and start the car.
There's the Only One that can, He knows whats the matter as He created it. My own experiences testify to me that He Is Able.
Old Jan 18, 2005 | 06:59 PM
andy044's Avatar
RWD bolt-on conversion?
no, hes got 32" tires and i think 3 or 4" lift i foget...
haha i was with him when that happend oh man
we had to evacuate pretty damn fast.water was up to our asses while sitting in the front seats
and it was around 5pm in MA on Jan 15th....little bit chilly just a little
but ill let him fill us in on how he drove it to work today
Old Jan 19, 2005 | 04:58 AM
minmaster1's Avatar
my throttle still freezes up, door locks freeze, doors freeze shut, computer inside is a little whacked out- so it wont upshift nicely-or go past 2500 RPM, seats still a little wet. other than that it runs great.
Old Jan 19, 2005 | 01:50 PM
spyhunter84's Avatar
just wondering what exactly happens when a car hydralocks?
Old Jan 19, 2005 | 01:52 PM
Jeff92se's Avatar
I'm needing a caw
Water in the combustion chamber. Water is not compressible. Piston + water + heads = not enough space. Piston can no longer move. Or piston will attempt to move anyway. So something has to give. Most of the time, the water wins.
Old Jan 19, 2005 | 02:05 PM
oh ok gotcha
andy044's Avatar
and thus, you break a conrod
Old Jan 19, 2005 | 02:09 PM
Jeff92se's Avatar
I'm needing a caw
Aren't conrods inside a manual transmission?
Old Jan 19, 2005 | 05:45 PM
andy044's Avatar
i dont know, ive always thought
con rods (connecting rods)
connect the piston to the crankshaft
Old Jan 19, 2005 | 06:01 PM
emmas97's Avatar
you are VERY lucky your motor didnt hydrolock.... usually if a motor stalls when flooded, youre screwed..... even though it still runs, keep an ear out and listen because something still may be messed up (other than the ECU)
Old Jan 19, 2005 | 09:13 PM
if the car is flooded that bad, MANY electronics might have been shorted out, fuses shot, etc....Poor car....even though it had been submerged by its owner, still loves him enough to run in limp home mode and still gathers enough power to take the abuse. Anyone got a tissue? (no, not for my one eyed snake your sick ****)
MikesChevelle
Nov 23, 2024 11:17 AM
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
Balkins
Aug 12, 2015 06:39 AM
altome15
Aug 10, 2015 07:05 PM
