Installing Injectors.
Old Jan 27, 2005 | 01:07 PM
Evil_Twin's Avatar
I received my injectors from Brian today. I got 1 injector out, and tried putting the new one in with the new o-rings. How do they go in, I don't want to break it. Anybody have some tips?
I will to you forever.
Old Jan 27, 2005 | 01:17 PM
95turbo gxe's Avatar
Got Boost?
Old Jan 27, 2005 | 01:22 PM
mtcookson's Avatar
well... what i did with mine was set the injector in there where its supposed to be then put that cap on and light tap it in with a hammer. i'm not sure what the proper way to do it is in the manual but this worked for me. no leaks or anything. (not doing it that way landed me leaks )
Old Jan 27, 2005 | 01:31 PM
fred's Avatar
yes that is what i did too... other wise there is no way you are going to get it in...put the metal holder piece over it, put a screw driver on it, and -LIGHTLY- tap the screw driver with a hammer. after you think it is in, pull the metal cover off and twist the injector around to make sure it is seated properly.
edit: thanks jeff, i forgot to mention that
Old Jan 27, 2005 | 03:48 PM
Jeff92se's Avatar
I'm needing a caw
Make sure you lightly lube with vaseline or similar. If you tear/pinch the o-ring, you will have some bad leaks.
Does anyone read the stickies? Autozone owns joo.
Old Jan 27, 2005 | 04:38 PM
mtcookson's Avatar
is the vaseline safe on rubber?
Old Jan 27, 2005 | 04:40 PM
Jeff92se's Avatar
I'm needing a caw
We aren't really talking about the same rubber are we?
Old Jan 27, 2005 | 04:42 PM
mtcookson's Avatar
i'm not talking about latex rubber...
Old Jan 27, 2005 | 05:12 PM
Evil_Twin's Avatar
I didn't want to hammer on it, so I put the cap on and then put the screws in and screwed it in. I hope it's seated correctly.
Old Jan 27, 2005 | 05:23 PM
jwmaxse's Avatar
Are you and Jeff talking about the same thing?
And silverlinekenne, what's up with the boost gauge?
Old Jan 27, 2005 | 05:37 PM
mtcookson's Avatar
nonononono.... definitely don't do that. there's a high chance you'll get this if you do:
i tried screwing it on and it didn't seal properly. when i used the hammer it sealed perfectly.
Old Jan 28, 2005 | 06:09 AM
internetautomar's Avatar
mod or sell?
vaseline will eat rubber.
KY won't
MaxLife17
Jun 27, 2019 01:37 PM
Excalibur23
Oct 13, 2015 04:33 PM
Max8
Sep 22, 2015 02:53 PM
2kmaximel
Sep 16, 2015 03:19 PM
Johnny9595
Sep 3, 2015 05:18 AM
