New Timing Belt Replacement info?
Can you guys tell me if there is a how to ON Setting motor to top dead center for the timing belt replacement? I had to take the coolant neck loose to get the timing cover off. It looks lke I will have to remove the cam sprockets then the timing cover backplate to reinstall
the coolant neck. Are there any marks on the crank and cam sprockets for TDC. If anyone has the instructions for water pump/timing belt replacement on 93 SOHC maxima GXE please reply to this thread.Thanks in advance,JEff
Maxima2010 Prem
08-13-2015 11:34 AM
