To all that have replaced their cats......
Old Feb 10, 2005 | 02:58 PM
5 ltr. beater's Avatar
anyone notice a difference in engine performance/acceleration/drivibility?
Old Feb 10, 2005 | 03:48 PM
HTPerformance's Avatar
I replaced mine when i replaced the y-pipe, so i cannot tell directly.
Brian
Old Feb 10, 2005 | 03:58 PM
MrGone's Avatar
not really, spend the money somewhere else
Old Feb 10, 2005 | 04:05 PM
95turbo gxe's Avatar
UMMM I had to through a could cat away.
Old Feb 10, 2005 | 04:11 PM
Jeff92se's Avatar
I'm needing a caw
Mouthfull of peanut butter?
Old Feb 10, 2005 | 04:27 PM
DanNY's Avatar
Ad·min·is·tra·tor
Old Feb 10, 2005 | 04:32 PM
505max94se's Avatar
You might notice a difference in sound.
Old Feb 10, 2005 | 04:49 PM
Minty91GXE's Avatar
yea a cat doesn't ever make you run better, its only there for environmental reasons.
Old Feb 10, 2005 | 06:30 PM
Cliff Clavin's Avatar
Way out West
IIRC, Aaron noticed a difference in his 1/4 mile time, but I think it was minimal. Definitely not anything noticeable on the butt dyno going with a test pipe or a high flow cat.
I think the price on a high flow cat is cheaper than a regular one, so I would go that route if you think yours needs replaced. However, I would fix whatever is causing your cat to clog first.
Old Feb 10, 2005 | 07:38 PM
I don't think it's clogged. It's just that my car has 133K on the clock and i have the original cat. on there. I just figured it might be time to replace it. in the meantime the car is not giving me any signs that the cat might need to be replaced. I just figured that i might feel a slight difference with a new high flow cat on there as opposed to one that has 133K on it.
Old Feb 11, 2005 | 07:11 PM
Aaron92SE's Avatar
NWP Engineering.com
Yeah. I have compared my stock cat and my testpipe many times. I shaved exactly 1 tenth in the 1/4 mile. I lose noticable low end power on the street and I gain noticable top end power. So you can tell a difference. The low end loss is actually more noticable since you spend 90% of your time below 4K rpm. Well, personally, I only spend 50% of my time below 4K since my throttle is an ON/OFF switch.
Old Feb 11, 2005 | 09:43 PM
Harvs94max's Avatar
i didnt notice anything big other than a nice growl paired with a y-pipe even with a stock muffler at wot it sounds real nice
Old Feb 12, 2005 | 08:20 AM
dmontzsta's Avatar
Ford Only.
I have switched from test pipe to high flow a bunch of times and I am keeping the high flow this time. It is much quieter and I like to know I am not polluting the air, I do not notice much of a difference between the two and not much of a difference between stock and high flow cat. I would leave it alone unless you are boosting.
PH98I30
29
Feb 10, 2025 12:03 PM
captchaos
Mar 15, 2016 12:18 PM
dvcamp
Sep 18, 2015 10:17 AM
dcam0326
Sep 8, 2015 11:02 PM
Maxima30
Sep 7, 2015 06:13 PM
