Help! My VG is missing when it runs!
Old Feb 11, 2005 | 10:58 AM
PulsarDriver's Avatar
Agh! Its running like it has a loose wire or something! Idling rough, chugging along, and has some plap-plap noises out the tailpipe.
The car has a fairly new NAPA Echelin cap and rotor (both looked okay from underneath I guess...Some white on the metal bits.) and newer NGK copper plugs and NGK wires. I have no idea why its running this way! Help :| It seemed pretty good yesterday...idle was just slightly rough.
I need to get this car to run right *SOON*
Old Feb 11, 2005 | 11:08 AM
internetautomar's Avatar
mod or sell?
I'll bet it's an injector.
start by isolating which cylinder is having the problem.
then check it's wire, and plug.
Clean the terminals on the injectors.
Old Feb 11, 2005 | 11:09 AM
Scope's Avatar
Im izz sexay
Did you make sure all of your wires are correct? Are your plugs properly gap? Did you check your timing? Try resetting the ecu by taking the battery terminals off for about an hour.
Old Feb 11, 2005 | 11:14 AM
I figured it out using the time-honored pull the wire test.
Pulling the wire off of cylinder #3 makes no difference on how the car runs. I bet the wire is bad. Damn...my first bad set of NGKs
To me this just seems like a bad wire (this has happened to me before twice on different cars, actually) or is it something more sinister? I'm going to check the plug on that cylinder right now.
Old Feb 11, 2005 | 11:17 AM
Wiking's Avatar
...yess, and the other end of the injector wire(s) also = ECU connector.
Check all sensor outputs.
Only copper conducts electricity: make uself real wires instead of those NGK soothoses.
http://www.cardomain.com/memberpage/748507/1
Old Feb 11, 2005 | 11:18 AM
mod or sell?
Measure the resistance, but I'm still betting on injectors.
Old Feb 11, 2005 | 11:28 AM
How exactly do I test resistance? I don't think I'm equipped to do that.
The plug looked normal, not burned. Had a slight yellowish-white stuff on it, but so did the plug on cylinder 1, which I pulled out to check.
Old Feb 11, 2005 | 11:29 AM
wawa92gxe's Avatar
as said, you need a new injector.
Been there, done that.
good luck.
Old Feb 11, 2005 | 11:33 AM
Great :\
Oh yeah, I forgot to mention:
It ran funny when I put these new NGK wires on when I got them at xmas time. It started to run just like this. But then I got all the connections nice and tight and stuff, and it ran good...until today. It was wires 1 and 3 that seemed to cause the problem before...thats probably it today. I can't believe I forgot about that until just now.
Old Feb 11, 2005 | 11:47 AM
Okay...its probably the injector >:|
I just swapped the wires for 1 and 3 (on the cap and engine, of course) The wires are all good...
IS my engine likely a blue or black mark injector?
Old Feb 11, 2005 | 11:52 AM
lalo's Avatar
Did you replace the Plug wires by yourself? did you check the gap on the spark plugs?
if not, make sure you pluged the wires in the correct order other wise you would have a ruff ride.
internetautomar just jumped to the injectors because he has replaced so many on his car. ( I think 5 or so) but that could also be your prob. and they are prety expensive...
so if you think your cap/rotor maybe damged I would suggest replacing it, cap $25 & rotor $5, injector are more expensive and I heard its better to get new than remanufactured/refurbished. ask internetautomar he should sell them.
So check for spark: While engine runing remove a spark plug wire if car runs worse, then that spark plug is working if wire is removed and there is no change in the engines behaviour than you cylinder is down. SO if your cylinder is down could be injector/spark, but you would know what cylinder is the one with the prob. hopes this helps I tend to give info that is not understandable.
Old Feb 11, 2005 | 11:59 AM
aminus21's Avatar
check the resistance on the injector. Buy a multimeter~~$20-30. Touch each of the injector connectors with the two pins from the multimeter. It shouild be between 10-14 ohms.
Old Feb 11, 2005 | 12:11 PM
I did all of this already, check my prior posts.
At this point it has to be the injector I think. No vacuum leaks found, no problems with the ignition parts, and its just #3. I cleaned off the connectors for the injector, and double-checked all of the ignition stuff. Its running a bit better, but still clearly far from right. There's also a lot of plapping and a lot of condensation or water splattering from the tailpipe. I'm going to call around about injector installs now, since I really don't want to do it. I'll probably just end up ordering the injector from a guy in Cali who does new Bosches for $90 shipped, and then probably just have my cousin's repair garage install it.
Old Feb 11, 2005 | 12:12 PM
Jeff92se's Avatar
I'm needing a caw
Plug that spark plug and inspect.
Old Feb 11, 2005 | 12:14 PM
Plug it? Do you mean pull it?
Already did...read above.
Jeff92se's Avatar
I'm needing a caw
Pull the sparkplug
Old Feb 11, 2005 | 12:17 PM
maximapitko's Avatar
The Bulgarian Guy
I had a bad injector and it was barely noticable-a little vibration and a little lack of power. Although it's a possibility, I would check the darn wires first...Just put back the old ones and see how it works....
Old Feb 11, 2005 | 12:22 PM
I tried switiching wires around...all of them worked fine...no matter which one you put on three, it won't change the way the engine runs when you pull it off. And they worked fine on 1.
I can get an injector for 87 bucks shipped and have it installed for about 70. I'll probably just do that.
Old Feb 11, 2005 | 12:27 PM
The Bulgarian Guy
damn...that's dirt cheap for labor...I am just wandering if you'll need new intake gaskets cause this alone is $60-80...Anyways, excellent price...
Old Feb 11, 2005 | 12:28 PM
lalo's Avatar
PulsarDriver "I did all of this already, check my prior posts"
when I started typing there was only one reply on your thread
(internetautomar), but since im at work it takes me forever to reply, other people posted what I was typing. I was supposed to be the 3rd reply but im too slow.
Edit: read the new post and yea sounds like its an injector (#3). ill be faster next time
Old Feb 11, 2005 | 12:53 PM
Happens to the best of us
I'm ordering the injector now.
I plan to order plenum gaskets too...is there anything else I need?
Old Feb 11, 2005 | 01:02 PM
boosted3rdgen's Avatar
try adjusting your fuel on the IAC, the same thing happened to my car last week, i replaced every ignition compenent and it still ran rough. I adjusted the fuel and now it runs like a top. BTW its under the little black plug on top of the IAC. It may work or it may not but if it does then it saved you $157
Old Feb 11, 2005 | 01:07 PM
What am I looking at for Gaskets and stuff? I plan to have my plenum gaskets replaced...anything else I should get?
maximagxe90's Avatar
Hi,
don't forgot to order those o-ring seal for the injector to,
Old Feb 11, 2005 | 01:09 PM
Check What else?
Should I replace my upper and lower injector holders?
Old Feb 11, 2005 | 01:41 PM
I ordered:
1 Bosch injector
o-rings
plenum gaskets
injector holders.
Old Feb 11, 2005 | 01:42 PM
The Bulgarian Guy
never heard of those holders Make sure you have some nice screw drivers because you might have problems unscrewing the plate that holds the injector in place...since you are there already, why don't you change the rubber hoses as well. It will take you extra 15min but why not...When you're unscrewing/screwing the upper/lower intake make sure you do it in the correct order...hmm,can't think of anything else. It takes some time the first time you do it but it's not a big deal...
Old Feb 11, 2005 | 01:45 PM
Jeff92se's Avatar
I'm needing a caw
http://www.4dsc.com/articles/drivetr...lacement.shtml
Old Feb 11, 2005 | 01:58 PM
Holders are also referred to as "insulators" I'm not sure I've ever seena car that didn't have some sort of one, but maybe I don't need it *shrug* They weren't exactly expensive. They're usually part of a seal kit.
Old Feb 11, 2005 | 02:29 PM
wawa92gxe's Avatar
as mentioned by maximapitko, be very careful on those screws. they are soft and tight.
I used a small locking plier instead of a screw driver, worked well.
Old Feb 11, 2005 | 02:56 PM
I'm letting someone else install the stuff Let them deal with it.
Old Feb 12, 2005 | 04:31 PM
mod or sell?
Ding dong, I coulda saved you shipping.
I have a warehouse in madison.
Old Feb 12, 2005 | 06:44 PM
well i guess your not gonna try my idea, jus trying to save you money but seems as if you already ordered your stuff
good luck, i hope it works out for you
Old Feb 14, 2005 | 12:10 AM
You could've got me a new Bosch injector for $87 shipped?
Old Feb 14, 2005 | 06:56 AM
mod or sell?
mod or sell?
Ask nice and I'll throw in some o'rings
Old Feb 14, 2005 | 07:01 AM
bhunter's Avatar
How about some french fries too??
Old Feb 14, 2005 | 07:06 AM
mod or sell?
if you supersize the order I will
Old Feb 18, 2005 | 03:14 PM
Yay! New injector is in! It didn't run right after I got it back, but thats because the tech hadn't got one of my ignition wires on right. It runs good now, feels smooth from the driver's seat, save for some little idle jiggles.
With the hood open, I can see that he engine isn't running *really* smoothly, and I think the problem might be vac lines. I found one that was clearly fuxx0red and replaced it, which made an improvement. I've uncovered more that could stand replacing, but I have a question.
That arrow is pointed to a black metal canister. The only things attached to it are 2 vacuum lines. One goes to straight to the plenum, but the other has some sort of little round thing along the route of the line. So it goes Canister-->line-->round thing with nipple on each side--->line-->plenum.
What is that little round thing? Some kind of filter? I think if I'm going to replace those lines, replacing that thing probably isnt' a bad idea, eh? But first, what the hell is it?
Old Feb 19, 2005 | 04:54 PM
mod or sell?
what's the long black thing snaking around your engine?
oh yeah, it's a VG's intake hose
captchaos
Mar 15, 2016 12:18 PM
conansriver
Nov 18, 2015 02:46 PM
ballerchris510
Sep 11, 2015 05:29 PM
ballerchris510
Sep 10, 2015 09:35 PM
A32goldylocks
Sep 2, 2015 06:39 AM
