&*@%! windo reg.
Old Feb 14, 2005 | 05:25 PM
NewEngSurf's Avatar
&*@%! windo reg.
So i got a new back right window regulator from auto zone the other day. Took out the old one, transfered the motors, installed the new one. Everything went smoothly but the window doesnt go up all the way, stops about a 1/6 inch from the top. The regulator and motor fit in pretty snuggly in the wholes so i dont think its mounted to low. Has this happened to anyone?
Old Feb 14, 2005 | 05:27 PM
avmaldo's Avatar
make sure the window is in the track right. if it's off just a little it will make it slow and it wont go up all the way.
Old Feb 14, 2005 | 07:11 PM
«§»Craig B«§»'s Avatar
Loosen the mounting bolts for the regulator and the tracks (two bolts up top and down low) and try the window. Just mess around with those adjustments a little and you should be allright.
Old Feb 14, 2005 | 08:07 PM
Cliff Clavin's Avatar
Way out West
If you look at the mounting holes on the upper part, they are oval to allow for adjustments.
I did the exact same thing as you. I mounted the new regulator in the exact spot where the old one was (there were marks from the bolts) and the thing stopped about 1/2 short. However, the new regulator must have been a touch different, so I moved the bolts and it was fine.
Cattman
May 17, 2007 01:28 AM
Cattman
Apr 17, 2007 10:23 PM
Cattman
Feb 22, 2007 11:27 AM
Cattman
Nov 24, 2006 07:06 PM
Cattman
Oct 29, 2006 11:45 PM
