Replacing Antenna
Old Feb 14, 2005 | 10:47 PM
Ivan Yulaev's Avatar
Replacing Antenna
Ok, so, my antenna is really starting to **** me off, it is getting worse and worse about going down. What are my options about fixing it?
I was thinking about putting in an aftermarket antenna that is stationary. What do I need as far as an adapter for the diversity antenna?
Old Feb 14, 2005 | 11:28 PM
Wiking's Avatar
Try helping the dying first...
Lubricate the antenna with lithium grease, take down/up 10x, wipe off.
Make hole [solder-iron tip] on top of the antenna gearbox (trunk) and spray in lithium grease... close hole.
These should be done periodically - the motor will last 'forever'...
Old Feb 14, 2005 | 11:49 PM
It seems like when I lubricated it, it would temporarily get better. I used WD-40 last time though (I was stupid), I will try with grease this time. Should be better...
About the gearbox...how do I 'spray' grease in?
Old Feb 15, 2005 | 12:18 AM
Wiking's Avatar
WD-40 is okay for brief period, but it tends to evaporate.
I know two ways, first I explained above
II Second is to pry open the antenna gear body from middle, just ajar, spray in, close
Old Feb 16, 2005 | 07:39 AM
91maxi's Avatar
where can i buy a new power antenna - and how hard is it to replace, the dam paper boy broke mine
Old Feb 16, 2005 | 07:51 AM
«§»Craig B«§»'s Avatar
check out the FAQs, antenna replacement is on 4dsc.com/articles
PH98I30
29
Feb 10, 2025 12:03 PM
captchaos
Mar 15, 2016 12:18 PM
dvcamp
Sep 18, 2015 10:17 AM
dcam0326
Sep 8, 2015 11:02 PM
Maxima30
Sep 7, 2015 06:13 PM
