rusted exhaust bolts...these suckers are no joke!!!
Old Feb 16, 2005 | 12:18 PM
ChrisCheezer's Avatar
im slowly gathering parts for my ve5 , and i noticed my Bpipe to CAT bolts are sooo rusted u can't even see the shape of the bolts... its just a big rusted blob.
i have never delt with bolts this bad before... i have heated rusted bolts out with a torch, but these seem waaaay to rusted.
they must be removed along with the cat... to install my "high flow cat" but now im thinking when the time comes, ill be forced to replace that pipe or at least make a new flange for the B pipe. If i had the money, there would be no question on replacing the pipe (it doesnt leak at all but it is old)... i have other plans and wana keep the stock b pipe.
has anyone heated bolts out or made a new junction between these two pipes, i have no experience welding pipes or flanges...
Old Feb 16, 2005 | 12:26 PM
-shock211-'s Avatar
i would first try to clean the bolts off with a wire brush on a drill. then i would heat em' up and try, try again.
if that doesn't work and you just end up stripping the nuts, drill em' out. get a cobalt drill bit in the size that you need drill....and you'll be home free.
Old Feb 16, 2005 | 12:30 PM
cobalt? drill bit
Old Feb 16, 2005 | 12:34 PM
subs1000w's Avatar
i had the same problem and ended up having to pull the whole Bpipe/cat out from under the car as one and then i cant remeber how but i got them separated with out cutting the flang off and then used new bolts to connect my test pipe
Old Feb 16, 2005 | 12:57 PM
Jeff92se's Avatar
I'm needing a caw
Nut splitter.
Old Feb 16, 2005 | 12:59 PM
can't remember??... were you sleep modding again?
... nut splitter huh?... sounds interesting.. but i dont have a nut splitter and i dont think i have to tools to split a nut, so i dont think ill be able to split thoes nuts... hehe
Old Feb 16, 2005 | 01:28 PM
subs1000w's Avatar
im sure it involved an assorment of different tools ranging from vise grips to hammers to breaker bars with a 3 or 4ft helper pipe but it was over 2 years ago and i really dont remember
nut splitters a good idea
Old Feb 16, 2005 | 01:49 PM
MrGone's Avatar
I concour with Jeffy on the nut splitter.
or you could dremel them off but you will probably ruin a flange or atleast use alot of discs.
oh dont forget to buy new bolts before you start working on the car.
Old Feb 16, 2005 | 07:58 PM
ok... so i guess ill split the nuts...lol
i got all new hardware with my highflow cat
... the parts wont go on for another few weeks, i just wana get everything in order, so i can install y pipe cat cai and sts in the same day... now i just need KLoWnPR109 to come out of hiding and give me my sts......
Old Jan 30, 2011 | 01:07 PM
kel456's Avatar
does nut splitter work on the flat side that acts as a washer? no grip there?
Old Jan 30, 2011 | 01:09 PM
CMax03's Avatar
Cut them off with a cut off wheel, then drill thru the rest and the threads to use a bolt and nut setup SS of course!
Old Jan 30, 2011 | 01:17 PM
kel456's Avatar
cut if off with a dremel? drilling can accidentally damage the thread since there is no place to sit a drill bit?
Old Jan 30, 2011 | 01:30 PM
CMax03's Avatar
Don't worry about damaging the threads they're damaged already drill thru it all to make a larger bore for a bolt ,washer, lockwasher, & nut setup....This is easier to work with......and easier to replace in the future!
Old Jan 30, 2011 | 01:55 PM
kel456's Avatar
i see. i guess reciprocating saw doesn't work because the blade is to thick. i guess it has to be dremel?
Old Jan 30, 2011 | 02:33 PM
Matt93SE's Avatar
STFU n00b!
Don't worry. This thread is SIX YEARS old. The problem is long gone.
RealityCheck
Oct 2, 2015 06:34 PM
Justin Kroll
Oct 1, 2015 07:03 PM
uttadms31
Sep 30, 2015 05:24 AM
Socalstillen
Sep 26, 2015 12:01 PM
