ecu toast!!
Old Mar 9, 2005 | 10:36 AM
michaels'max's Avatar
ecu toast!!
Well It's pretty much as I thought, my ECU is toast. The coolant from the heater core that leaked a couple of weeks ago got into the unit and fried it. I think my TCM is messed up as well.
A couple of questions.... 1. The dealership says that after the instalation is complete the ecu has to be reprogramed, is this true? From my understanding the ecu basically gets all of it's information from the drivers "habbits" and the sensors and makes it's adjustments as neccessary.
2. They also said that the part # on my ecu ( 2371A-87E10RE) would have to be matched with an ecu of the same part #, same thing for the tcm. Is this true?
Any information would be helpful.
thanks.
Old Mar 9, 2005 | 11:03 AM
Wiking's Avatar
1. Stealer$hip Tale, not told in FSM.
2. Many ECU's around, all will not fit in. Suppose last letters ? are revision, can be ? different. Get one from scrapyard with return right, tst.
Old Mar 9, 2005 | 11:06 AM
I found an ecu from a used auto place for 65$ they suppositively warranty all their parts for 90 days. as long as the #'s match I think I will try it.
Old Mar 9, 2005 | 11:27 AM
Wiking's Avatar
The ECU has to play with the TCU as/if u got autotranny, I suppose manual ECU does not fit, also VG vs VE should ? be different.
Old Mar 9, 2005 | 12:36 PM
internetautomar's Avatar
mod or sell?
if the #'s match exactly you will be fine.
Old Mar 9, 2005 | 12:42 PM
Cliff Clavin's Avatar
Way out West
You didn't mention what type of car and/or engine you have, but the VE automatic ECU will work in the 5-speed, but the variable intake won't function. I swapped in MrGone's and my car ran fine, just didn't have the VI.
That is something to consider in a pinch, if you can't find a 5-speed one. I would imagine the VE automatic ECU is pretty common and you should be able to find one, same with a VG automatic ECU.
If you have a VG automatic or 5-speed, I don't have any information on swapping and you are best served getting one that matches.
Old Mar 9, 2005 | 01:32 PM
yes but, what about reprograming? is it like "plug n' play" or do I really have to bring it back to the dealership for them to screw around with it before It would work?
Old Mar 9, 2005 | 01:42 PM
mod or sell?
plug and play on a used ECU.
Old Mar 10, 2005 | 02:18 AM
Wiking's Avatar
Look at Nissan TSB's. NTB93-167.pdf
That contains lis of all ECU's.
click http://maxima.theowensfamily.com/tsb
Old Mar 10, 2005 | 07:14 AM
well, I got the ecu and tcu from a junk yard. paid 163.00 for both. went home and pluged em' in. Thank god my car works now. thanks everyone.
Old Mar 10, 2005 | 07:49 AM
Wiking's Avatar
Grreat! Tell about the former/current box versions/numbers.. please.
U should clean the connectors, if/as they were soaked to clygol... No problem today (perhaps), but later will be. Warranty on that...
Old Mar 10, 2005 | 07:48 PM
HTPerformance's Avatar
Yikes... shop around much?
thats highway robbery...
Brian
Old Mar 11, 2005 | 05:51 AM
mod or sell?
getting a part that works right immediatly: Priceless
Old Mar 11, 2005 | 08:18 AM
maxzella's Avatar
I tried to sell you the same parts from a 92 max for 40 bucks each, would of save you half. If anyone still needs them, they are available.
gigabyte
Jan 6, 2017 06:05 PM
Omar Abdurrahman Siddiqi
Aug 26, 2016 05:18 PM
BLACKKILA.GTR
Sep 29, 2015 11:23 AM
imported_Nismo_max
Sep 20, 2015 08:19 AM
QueensMAX
Sep 15, 2015 04:14 AM
