Gauges...
Old Apr 2, 2005 | 11:07 PM
505max94se's Avatar
Gauges...
How do you remove the needle from the guage? I'm installing indiglow guages and I need to know.
Old Apr 3, 2005 | 12:22 AM
imported_Maxima_Mike's Avatar
I didn't need to remove the needles to put mine on. The covers just slipped over them. I did have to shave a little bit off of the back of the needle on the speedo, because it was sticking. Other than that, covers slip right over needles. If you are auto, you will probably lose the "O/D Off" light, because most brands don't have them on there.
*EDIT* I see that you are not auto, so disregard last sentence.
Old Apr 3, 2005 | 05:36 AM
spyhunter84's Avatar
they have special tools to pull the needles off but i just gave them a yank and they came off, i only had a lit trouble with one but it eventually came off.
Old Apr 3, 2005 | 06:24 AM
disgruntled's Avatar
if you are going to yank your needles, at let the needle come to their "full rest" which is below the pin that stops them normally, then mark that location so when you put the needle back on, you can align it and not worry too much about messed up reading. Also, since the shaft of the needle's motor is so thin, try to pull the needle as straight away from the shaft as possible.
Old Apr 3, 2005 | 08:20 AM
-shock211-'s Avatar
very carefully...
Old Apr 3, 2005 | 03:07 PM
Akuma2001's Avatar
The Fuel pin and engine temp pin come off. The RPM and the MPH pins don't therefore you will have to thread the pin through the gauge. Be very gentle because the pins base can crack easily.
Old Apr 3, 2005 | 03:34 PM
bobbydigital450's Avatar
yeah, i cracked mine on my old max. like everyone else has said. be careful and be patient
Old Apr 3, 2005 | 04:04 PM
505max94se's Avatar
I just slipped the new gauges thought the needle and over the old guages. I did break off a couple of the needle resting points in the process but I fixed them with super glue.
The gauges look weird because I think they're bigger than the stock ones. I'll probably enlarge the holes in the trim piece that fits over the gauges (black part with large circles in it) so that it looks right.
Thanks everyone for your input.
zhuk90
Mar 19, 2011 09:01 AM
S1cTech
Feb 17, 2008 01:50 AM
NismoMaxman2
Jan 12, 2005 02:32 PM
BORQUA79
Dec 14, 2004 02:22 PM
