squealing engine.......
Old May 9, 2001 | 05:59 PM
DAREN's Avatar
when i start my car it squeals. the noise is not coming from my accessory belts. when i put my head near the engine i heat it coming from the heads. when the car warms up it goes away.
TIA
Old May 11, 2001 | 10:17 AM
davis449
Ok First of all, what year and model is your car. I have the same problem, exactly. Mine squeals when it starts and when you rev the engine about three or four times and then the car warms up and it goes away. The Nissan dealer told me it was belts and at the time all me belts were cracked and worn so they replaced them. This didn't solve the problem. Let me know if you find the solution.
Old May 14, 2001 | 01:00 PM
91 Max's Avatar
i had this problem...i took it to the dealership...they tweeked the Air Conditioning belt and everything has been fine since...good luck
Old May 14, 2001 | 01:35 PM
DanNY's Avatar
Ad·min·is·tra·tor
i would say in your situation check the bearings in the alternator and related components and idler pulley(s).
Old May 14, 2001 | 05:14 PM
DAREN's Avatar
i have a 93SE 5SP. i did the same thing when this first started. even after swapping the belts it was still there. i am going to replace the idler pulleys (accessory belt tensioners), front crank seal, oil pan gasket all in one shot so wish me luck. sooner or later my baby will get an overhaul: new rings, gaskets, bearings, pistons/rods-lightweight aftermarket stuff if possible.
Old May 14, 2001 | 06:34 PM
89GXE
Make sure the belts are tight enough.
02PearlSE
Oct 7, 2015 02:12 AM
Loe max
Aug 13, 2001 11:29 AM
bill99gxe
20
Aug 1, 2001 08:29 AM
Botnik
Jan 7, 2001 07:32 PM
Mike S.
Sep 4, 2000 08:35 PM
