Need Help!! My Max Will Not Start!!
Old Apr 16, 2005 | 09:28 AM
nForce's Avatar
The Computer Guy
HI,
I went to start my max up and it would do anything only the lights on the cluster appeared. This has happend before to me about 4 times but this time it didnt turn over. I tryed to reset the theift system because I thought that it would be shorted with somthing. Maybe it is cutting off the starter or somthing can any one help me ASAP!!!
THANKS
Old Apr 16, 2005 | 09:33 AM
bhunter's Avatar
Originally Posted by nForce
HI,
THANKS
If it's the alarm, try opening/unlocking the trunk or passenger door with your key. Then try to start your car.
Old Apr 16, 2005 | 10:03 AM
Schwagoo's Avatar
yea that, and try unplugging the battery, then replugging it (caution, the alarm WILL go off at this poing lol)
Old Apr 16, 2005 | 10:11 AM
nForce's Avatar
The Computer Guy
I did do the unlocking and stuff but didnt try the battery yet, I am at work now so I will try it when I get home
Old Apr 16, 2005 | 10:36 AM
nForce's Avatar
The Computer Guy
Wat else could it be if its not the alarm system thing?
Old Apr 16, 2005 | 11:46 AM
Alex_V
Try lightly tapping on the starter, This might unstick the brushes of the starter motor.
~Alex
Old Apr 16, 2005 | 12:24 PM
Schwagoo's Avatar
and if those don't work, then fully disconnect the starter (don't take it off) and reconnect everything -of course reconnect the battery LAST.
tighten all the connections down real good. that was my similar problem recently
Old Apr 16, 2005 | 12:49 PM
lalo's Avatar
turn the Key all the way (ACC ON), I think. well turn it all the way and hold it there, (the starter will NOT engage), now with your other hand tap the shifter UP past "P" a few times. If the starter spins then you need to check that realay.
When you hit the BREAK you should hear a click, that is also realated to the shift realay thing (forget what its called). Hope that was clear and good luck.
Asuming your GXE is auto....
Old Apr 16, 2005 | 01:29 PM
eric93SE's Avatar
Try starting it in N and right above and below N. If it starts then its your shift cable bushings that need to be replaced. $5
Old Apr 16, 2005 | 02:26 PM
nForce's Avatar
The Computer Guy
I will try all of these when i get home. Thanks, The starter never did turn when this happens. Just so you know.
Old Apr 16, 2005 | 08:11 PM
maxitech's Avatar
DO NOT tap on the starter. I forget what the term is for the starter design, but tapping it as you would do on a traditional starter will really f*** it up.
Old Apr 16, 2005 | 08:45 PM
Scope's Avatar
Im izz sexay
Just play with the shifter. It sounds like a bushing. With the car still in P jiggle the shifter up and down a few times. That's what it sounds like because if the car isn't in P sometimes it won't start up or even attempt to. It has happened to me a few times.
Old Apr 18, 2005 | 06:33 AM
nForce's Avatar
The Computer Guy
Hey my max didnt start again yesterday so I jiggled the shifter and it started right up. Thanks
Old Apr 18, 2005 | 09:12 PM
jordanius83's Avatar
was it not in park?
Old Apr 19, 2005 | 06:29 AM
Scope's Avatar
Im izz sexay
Originally Posted by jordanius83
was it not in park?
Sometimes it'll be in park just the bushing could be a bit worn out so when you place it in P the tranny is in park it's just the signal the ecu gets that it's not in P so nothing happenes when you try to crank. My car did it to me yesterday. I'll try to crank it you can hear it turning then it'll stop all actions. I turn the key nothing happens. Jiggle the shift up and down while in all actuality it is still in P then it'll crank.
02PearlSE
Oct 7, 2015 02:12 AM
neilraz
Sep 11, 2015 07:36 PM
MaxLife17
Sep 8, 2015 02:36 PM
Hailstatejig
Sep 2, 2015 06:52 AM
Balkins
Aug 12, 2015 06:39 AM
