replacing E-brake
Old Apr 16, 2005 | 09:54 AM
Schwagoo's Avatar
replacing E-brake
My E-brake has ZERO tension, in fact I don't even think there is a cable in there
The previous owner got a quote of this replacement and it was outrageous.
What does it take to replace this cable $ wise, time wise, and difficulty-wise?
Oh.. 90 SE 5sp.
Old Apr 16, 2005 | 10:33 AM
Scope's Avatar
Im izz sexay
Oh.. 90 SE 5sp.
Go to a junkyard, find a parts car take it off of their and you'll see how hard it'll be. You won't get raped of stealership costs either.
Old Apr 16, 2005 | 01:05 PM
Speedracer92's Avatar
That's what I done! :-). I haven't put it on yet
Old Apr 16, 2005 | 01:30 PM
Alex_V
My ebrake barely works. Even in snow. For EX during the winter I drifted alot in parking lots. Even if I slammed on the ebrake the rear tires would barely lock up and swing the rear end out. I doubt it would do much now, with the tires having traction. Should I replace my ebrake too?
~Alex
Old Apr 16, 2005 | 09:50 PM
Governor's Avatar
Oh.. 90 SE 5sp.
you got drums in rear or rotors?..reason is..your cable might be installed incorrectly..my 89 has drums and I had same symptom but all it was is some
shade tree mechanic(aren't we all!) put it together wrong..good luck
Old Apr 17, 2005 | 04:16 AM
DaWifey's90's Avatar
what can my max do for me
same situation here....i took the rear wheels off and sprayed the springs with some pb blaster and apparently the springs were seized. they're not great now but at least i have some tension
Old Apr 17, 2005 | 11:06 AM
Chris Gregg's Avatar
Get Off My Lawn
Absolutely you need to make sure that your rear brakes are operating correctly first. I had one rear caliper that would not engage when the ebrake was applied. Ended up braking the ebrake cable. Replaced both and it felt better than it ever had. If I had just fixed the cable, it would not have addressed what the true problem was, which was the failing caliper. If you have drums, I say invest in upgrading to rotors while your in there. I've got calipers and brackets and used rotors if you can get the rest.
Old Apr 17, 2005 | 11:23 AM
tripleGmax's Avatar
governor, all SE's have rotors all around no drums. GXE's had drums in back if it didnt have ABS. id do the junkyard route if it were me.
Old Apr 17, 2005 | 11:52 AM
Get Off My Lawn
I went by governer's post, never looked at sig. It's an SE and has rotors. Thanks for the clarification tripleG.
Old Apr 17, 2005 | 04:55 PM
Governor's Avatar
Dolp!!!!!!!!!!!!
PH98I30
29
Feb 10, 2025 12:03 PM
captchaos
Mar 15, 2016 12:18 PM
dvcamp
Sep 18, 2015 10:17 AM
dcam0326
Sep 8, 2015 11:02 PM
Maxima30
Sep 7, 2015 06:13 PM
