Power Steering Pump
Old Apr 18, 2005 | 11:16 AM
majordan's Avatar
Power Steering Pump
Stealership quoted me $700.00 for the pump. Are they crazy?
Anyone out there no when one goes bad and signs to look for,
My fluid is OK, but I am hearing a noise when I press the gas
sounds like a bearing in the pump has went bad. Is this a hard
job to do yourself or should I shop around? Any better prices on
pumps out there? I have the 91 SE VG30E SOHC.
Jay
Old Apr 18, 2005 | 11:20 AM
Jeff92se's Avatar
I'm needing a caw
Not that hard. Read REPAIR sticky for procedure. Should be lots of used ones in the for sale section
internetautomar's Avatar
mod or sell?
ouch, that's too much, I'm about 1/5th that price.
Old Apr 18, 2005 | 12:08 PM
majordan's Avatar
Whats the with or without electric control?
jay
Old Apr 18, 2005 | 12:26 PM
majordan's Avatar
Also, do I reach it best from inside the passenger fenderwell?
Jay
Old Apr 18, 2005 | 01:23 PM
mod or sell?
jay
the with electric control has a wire on the pump
Old Apr 19, 2005 | 09:42 PM
crcorc's Avatar
When my pump went, the steering would give sort of a jerking-resistance when I steered hard, as well as a groan noise. I paid $50 for a used pump and it still is going after two years. the job isn't that hard, just a bit tricky for location.
Good luck.
Old Apr 19, 2005 | 10:23 PM
avmaldo's Avatar
I reccomend internetautomart. got my ps pump from him and it's great.
Install is not bad a all. Make sure you have a torque wrench, and make sure you bleed the system correctly. also there is a little o-ring that i didn't know about until i got into the replacement. I just went to checker and got a universal pack of o-rings, you want the o-ring before you start.
Good Luck!
lowpost99
Oct 26, 2025 06:53 PM
RWCreative
Sep 21, 2015 11:01 AM
imported_Nismo_max
Sep 20, 2015 08:19 AM
rnb754
Sep 14, 2015 11:39 PM
SusieQQ
Sep 9, 2015 12:14 PM
