ebay question
Old May 3, 2005 | 07:06 PM
StreetMax's Avatar
ebay question
Anybody know anything about this product or is this just another ebay scam junk part? Thanks http://cgi.ebay.com/ebaymotors/ws/eB...971877491&rd=1
Old May 3, 2005 | 07:13 PM
5 ltr. beater's Avatar
save your money dude; the VG is a cast iron block. Heat is going to invade your intake manifold no matter what. Even if the gasket changes the intake manifold by couple of degrees, you won't notice it and it DEFINETLY will not be worth the time spent tearing down to gain something noticeable.
the intake is 2 degrees cooler
Old May 3, 2005 | 08:01 PM
Akuma2001's Avatar
40 deg.= 1 hp therefore 2 deg.= .05 hp.
Not worth it!
Old May 3, 2005 | 08:45 PM
subs1000w's Avatar
since there reusable they would be worth it if you have to pull your intake alot
but your proboly not going to see a performance gain with them
Old May 4, 2005 | 04:16 AM
Mizeree_X's Avatar
Getting back to his roots
Actually, Aaron made a set of these for his VE and noticed a difference....it helps with the infamous VE 'heat soak'. I was actually trying to find someone to make a set for myself, hmmmmm.
Old May 4, 2005 | 04:39 AM
Wiking's Avatar
See the oval openings? There goes the hot liquid INSIDE the intake (stupidos conStruction!). These should be blocked alltogether to keep intake cold, and liquid should be taken out from the ends of the heads...
...see explanations for the [numbers] and lots other pics for the cooling circ at:
http://www.cardomain.com/memberpage/748507/8
Old May 4, 2005 | 07:12 AM
internetautomar's Avatar
mod or sell?
the intake has coolant passages to warm up the air intake charge when the engine is cold. it helps get the engine to operating temperature faster, and it reduces cold engine emissions <- main reason.
Old May 4, 2005 | 07:34 AM
Wiking's Avatar
That is rili true (er... stupidity).
When some go wanting real pwr [turbo], they even get the intercooler to counterattack that heating stupidity (and turbo compr heat) <- main problem...
All that enormous heat exhange-game bck and forth is paid at the pump. But stupidity continues as humans still cannot figure out how to evaporize gasolin particles evenly to air...
Old May 4, 2005 | 08:43 AM
Jeff92se's Avatar
I'm needing a caw
Apparently, this mod has been well documented on other cars. I already showed Aaron this ebay link. But he made one for the upper manifold not the lower. The good think about this one is it doesn't seem to change and dimensions like Aaron's upper manifold mod. But the thing is, the additional thickness also helped prevent heat transfer.
For the upper manifold, the Ve doesn't have any coolant lines going though it.
Old May 4, 2005 | 08:58 AM
Akuma2001's Avatar
So therefore would it be worth it?
Old May 4, 2005 | 09:00 AM
Jeff92se's Avatar
I'm needing a caw
Difficult to say actually. Wiking makes a valid point about the coolant being circulated on the lower manifold
Old May 4, 2005 | 09:02 AM
Akuma2001's Avatar
He claims 5% increase in horsepower.
Old May 4, 2005 | 09:05 AM
Jeff92se's Avatar
I'm needing a caw
Well then you have some choices to make:
1) Believe him and buy it.
2) Don't believe him and don't buy it.
3) Think about if it really does help or not and keep researching.
I for one am undecided so far. But I like Aaron's upper spacer idea. You have to change some stuff to accomodate the higher height though.
Old May 4, 2005 | 09:14 AM
used parts's Avatar
It's like phenolic spacers on any other Port injected engine.....heat soak will heat the intake anyway....but when at the track....if you are gonna push the car through the lanes and ice the intake....it may help for an extremely little difference. maybe something to get when you are already there replacing gaskets
Old May 4, 2005 | 09:23 AM
andy044's Avatar
RWD bolt-on conversion?
since we're on the topic of ebay ?'s
anyone know if these suckers 'll fit?
http://cgi.ebay.com/ebaymotors/ws/eB...971988366&rd=1
or
http://cgi.ebay.com/ebaymotors/ws/eB...971107437&rd=1
or anyone know a good pair of LED 1157 bulbs
cause i want my side lights to match my silverstar h.lights.
Old May 4, 2005 | 11:05 AM
tripleGmax's Avatar
chrischeezer has led 1157 bulbs, im thinking of getting them, as i rewired my corners to be bright all the time and they dont match my silver stars, so im gonna get some of those bulbs.
buy some for me too
Old May 4, 2005 | 11:23 AM
ChrisCheezer's Avatar
im trying to make my own intake spacer(s) to go with my ported and polished intake
1157 bulbs are much brighter! but get good ones, because I've seen crappy ones that dont put out much light.
-off topic, i have a mirror polished valve cover... and im almost done with the upperintake.. both polished to chrome and I'm getting all the bolts powercoated dark gold/bronze... my motor is going to be a bomb
Old May 4, 2005 | 11:44 AM
tripleGmax's Avatar
Originally Posted by ChrisCheezer
.. my motor is going to be the bomb
hope it doesnt blow up!!!
Old May 4, 2005 | 01:13 PM
lol..
4563 numbers
Old May 5, 2005 | 06:48 PM
Aaron92SE's Avatar
NWP Engineering.com
Good point! I vote for #4!! ... Don't believe him and buy it! Don't ever listen to anybody's HP gain numbers. All manufacturers are full of crap when it comes to that. But bottom line is, you will feel a low end gain if you do this strictly b/c you are lengthen the intake path!
I did this just for my upper IM and my TB. Both spacers were 1/4" thick and made of Teflon, which has great thermal characteristics and resist chemicals and has a broad heat range.
As for the upper IM temp... you can drive for 5 minutes and have the upper IM heat up to about the same as the lower IM... around 180 degrees. OR you can install this spacer and race your car HARD for an hour and have an upper IM temp of around 120 degrees!! It's seriously cool enough to touch your forehead to! Try doing that after racing your car for an hour without this plastic spacer!
Bottom line is, they are proven to work. But I can't vouch for this particular product. The guy doesn't tell anybody what they are made of. I've already talked to him and his communication didn't impress me. He's just like any other average ebay seller out there... doesn't know crap about his product. He might know about his product, but he doesn't say anything.
Too bad he doesn't make them for the VE or I would buy a set. I asked him to make a set, but he said he doesn't make them. He wouldn't tell me where he gets them from either. He simply ignored my email. That always pisses me off.
Old May 5, 2005 | 06:53 PM
Jeff92se's Avatar
I'm needing a caw
Aaron I don't think this one raises the lower IM. It can't or else the IM wouldn't fit anymore. So it's most likely the same thickness just a diff material
Old May 5, 2005 | 06:57 PM
Aaron92SE's Avatar
NWP Engineering.com
Oh I see. So it would replace the gasket? My stock gasket is about 1/16" thick. I don't see how the plastic would be that thick and still somewhat durable. When I make my own, I will probably get 1/8" - 3/16" thickness to ease the install process.
maxinout93
Oct 16, 2015 02:53 AM
londonflu
40
Sep 25, 2015 09:11 AM
pears
Sep 18, 2015 05:25 AM
DBear
Sep 14, 2015 08:33 PM
flu2000
Sep 14, 2015 12:34 PM
