Bring it back Part2 (Rough Idle)
Old May 24, 2005 | 09:49 AM
Prophecy1's Avatar
Well we are working on bringing back a 92 SE with 200,000 miles on it.
So far this is what we have done.
1) Changed plugs to NGK Plats with .39 gap
2) Oil Change
3) Cleaned TB
4) Changed Air filter
5) Made sure all coil packs were working and they are.
So why is the car idleing between 1500 and 2000 rpm? The idle isnt that smooth either.
Possibilities? Maybe Vacumm Leak? Maybe Idle Air Control valve? PCV valve?
What do you guys think/recommened I do?
Proph
Old May 24, 2005 | 10:45 AM
Prophecy1's Avatar
Come on where are the pros :P
Old May 24, 2005 | 05:37 PM
garbury's Avatar
Well, as someone on here says, for diagnotics you need to keep in mind three things that an engine needs; fuel, air and spark. You have checked the spark, and done minor maintenance on air. You could replace the pcv (cheap), and check out the iacv, timing and a bunch of other stuff that I don't know about. You should check to see if the engine is getting fuel (as in injectors). If I am missing something, at least you got a free bump.
Old May 24, 2005 | 05:56 PM
mtnbikeair's Avatar
I replaced the PVC valve on my VG and it made a noticable difference, i havent tried it on my VE yet tho
Old May 24, 2005 | 05:58 PM
Drivin Maxima's Avatar
yeah if its idleing consistantly around the 2000 range and not surging or bouncing all around, then I would look at the IAC Valve. Gain access to it and spray the hell out of it with carb cleaner and get it all cleaned out. The car does have 200,000 on it so its not gonna idle like a new car, but if the idle is high like that then Im thinkin that the IAC is stuck open from miles and mile of dirt. Good Luck
Old May 24, 2005 | 06:19 PM
Prophecy1's Avatar
Anyone have a picture of the IACV? I cleaned the throattle body and the butterfly plate but Im not sure where its at. I got a manual and an idea. Anyone got a picture?
Proph
Old May 24, 2005 | 07:28 PM
Nickpisp's Avatar
Proph
Try this:
http://www.cardomain.com/memberpage/748507/4
Old May 24, 2005 | 09:01 PM
Originally Posted by Nickpisp
That wont work cause its a VG...he has a VE.
Old May 25, 2005 | 11:15 AM
Prophecy1's Avatar
Bump for a VE picture?
Anybody?
Proph
Old May 27, 2005 | 04:42 PM
NewEngSurf's Avatar
IAC on the VE is located directly below the throttle body, to bad u already put it back together cuz ur gona have to rip it out again in order to get to the IAC. Hard to discribe wut it looks like, about the size of 2 decks of cards with hoses goin every which way and the valve
sctludwig
Sep 1, 2022 01:32 PM
mvm062
Nov 30, 2020 09:00 AM
Maxima30
Sep 7, 2015 06:13 PM
crazyespn
Sep 3, 2015 01:30 PM
Justin Kroll
Sep 2, 2015 11:06 AM
