Wheel Bearing Help
Old May 25, 2005 | 07:25 PM
Pauls 98 SE's Avatar
Wheel Bearing Help
In the process of trying to replace front wheel bearing. I have removed the caliper, rotor and axle nut. I assume the next piece to come off is the part with lugs.
Before I tear something up. Do I need a wheel puller to remove that piece? Or am I going about this wrong?
Thanks!!
Old May 25, 2005 | 09:07 PM
subs1000w's Avatar
you need to remove the 2 bolts holding the wheel hub (big part with lugs) to the strut (tall shaft with spring)and the cotter pin and nut holding the steering tierod to the hub and the 3 nuts holding the ball jiont to the hub (ON THE BOTTOM)
then you have to press the old bearings out and the new ones in or take it to a shop and have them do it or if you want to you could come down and i could help you do it (i have a press and have done my wheel bearings)
bbsitum
Sep 6, 2019 07:31 PM
londonflu
40
Sep 25, 2015 09:11 AM
Bonka
Sep 14, 2015 11:18 PM
jfl330
Sep 4, 2015 01:44 PM
boomerbrian
Sep 4, 2015 08:25 AM
