Oil Catch Can for 92 SE w/ VE30DE DOHC engine
Old Jun 15, 2005 | 07:23 AM
momaxima92's Avatar
All -
Does anyone have instructions for making their own oil catch can (goes between PCV valve and intake). My max w/ 160k is having some oil burning/smoking problems during longer idles, and I believe the catch can will remedy the problem.
I'd also be interested in purchasing a used catch can OR if you have a recommendation for any particular brand that would be helpful also.
thx, Mike
Old Jun 15, 2005 | 08:16 AM
DanNY's Avatar
Ad·min·is·tra·tor
wouldn't it be a better option to figure out why it's burning oil and smoking instead of putting a bandaid on it?
i mean if nissan felt that it needed a catch can to run correctly they would've put one in from the factory.
how's that PCV?
Old Jun 15, 2005 | 08:26 AM
Jeff92se's Avatar
I'm needing a caw
Hope he uses a garbage can. If he's having that much blow by, it will fill up really fast. Sounds like either a worn out engine or worn valve stem seals.
Old Jun 15, 2005 | 08:31 AM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
of course not
Old Jun 15, 2005 | 08:33 AM
DanNY's Avatar
Ad·min·is·tra·tor
auto drain valve?
Old Jun 15, 2005 | 08:34 AM
Wiking's Avatar
On some engines the valve seals may be changed while cylinder is fed compressed air to keep valves up. How it goes with VG/VE?
Old Jun 15, 2005 | 08:52 AM
internetautomar's Avatar
mod or sell?
auto drain valve?
nah, return line to the oil pan.
Just like a....... turbo
Old Jun 15, 2005 | 09:14 AM
disgruntled's Avatar
can someone clarify this for me since I'm not familiar with oil catch cans and what it does:
A. what does it do?
B. if there is a small filter on the catch can, can the pcv valve be permanently removed, or is it simply an "add on" to the pcv valve?
Old Jun 15, 2005 | 11:55 AM
momaxima92's Avatar
I originally thought worn valve stem seals, but seems like I would get a big puff of smoke at start-up, and I get nothing..... only get smoke when it idles for 20+ seconds or more. ALSO, if I red line it in 2nd gear for a mile or two (on the interstate) the smoke problem improves DRAMATICALLY for several drives, then gradually gets worse.....
Recently changed the PCV valve.
Spark plugs look great, so figure that rules out valve stem seals. Really not interested in doing work on it that is not necessary, esp. since the car is only worth about 2k....
Band aid would be fine at this point!!!!!
Old Jun 15, 2005 | 12:00 PM
momaxima92's Avatar
A. what does it do?
Catch can sits in the line between the PCV and the intake and "catches" the oil in the vapor being pumped in from the crank case - usually used in turbo charged vehicles because of the increased pressure. In my case, I think the old horse (engine) is getting more blow by (piston rings) as it has gotten older, and that is causing more oil (from the increased pressure) to get pushed up through the PCV.
Old Jun 15, 2005 | 01:46 PM
found this link with a tutorial, not for the 3rdgen, but same concept can be used and applied.
http://www.scoobymods.com/forums/showthread.php?t=3346
Mar 12, 2020 12:06 AM
londonflu
40
Sep 25, 2015 09:11 AM
97_GXE
Sep 15, 2015 06:47 AM
seesole
Sep 14, 2015 12:38 PM
ag90fox
Sep 9, 2015 12:22 PM
