E-Brake Tightening
Old Jun 30, 2005 | 07:57 AM
daggett92se's Avatar
E-Brake Tightening
I havent looked yet but if someone could help me out my car has about 125,000 and the E-Brake is gettting loose i can pull it all the way up although it's still decent i'd like it to be a lot tighter is there just a nut or bolt i can tighten to do this or what. I havent looked into this at all yet so just a little insight would help.
Old Jun 30, 2005 | 07:59 AM
Matt93SE's Avatar
STFU n00b!
check your rear pads and see what they're looking like for wear.
If they've got plenty of material left on them, there is an adjuster screw on the ebrake handle. you need a deep socket 10mm and an extension to get to it.
pull the rubber boot back around the e brake and you'll see it.
Old Jun 30, 2005 | 08:40 AM
tripleGmax's Avatar
fsm says 8-10 notches on a pull and that the light should first come on after the first notch is "notched"
Old Jun 30, 2005 | 09:37 AM
Matt93SE's Avatar
STFU n00b!
the light should come on as soon as you lift the handle- before the first notch.
Old Jun 30, 2005 | 09:57 AM
tripleGmax's Avatar
sorry i was going by what the fsm says.....is it wrong?
Noela
Sep 26, 2015 08:22 AM
thenewguyy
Sep 12, 2015 11:12 AM
ag90fox
Sep 9, 2015 12:22 PM
Lowered_a33
Aug 24, 2015 04:35 AM
Maxboy23
Aug 11, 2015 11:59 AM
