Keyless Entry install....worth the hassle?
Old Jul 17, 2005 | 01:08 PM
geoff.doctor's Avatar
I picked up a brand new keyless entry with 2 FOBs and that include the trunk poping feature for $25 at a pawn shop. I want to install it, and I got the wireing info from craigs site, but what else is involved. Do I need to hook it into the alarm, or will the alarm function as usual when the power locks are locked from the remote. Also, Where is the steering and ignition harness? Do I need to take the steering colum cover off or can I get to those wires under the dash somewhere.
Thanks in advance!
Old Jul 17, 2005 | 04:48 PM
Maxima Man's Avatar
I am thinking about buying a keyless entry but need help with the wireing of the lock/ unlock Thanks guys
Old Jul 17, 2005 | 06:43 PM
internetautomar's Avatar
mod or sell?
nothing a test light won't figure out
Old Jul 17, 2005 | 08:16 PM
subs1000w's Avatar
youll probobly need a relay to do trunk pop "wrong polarity with alarm and trunk trigger"
and youll probobly need to hook up "factory alarm disarm" i had to on mine
Old Jul 18, 2005 | 05:34 AM
Maxima Man's Avatar
what wires do i tap into to activate the lock unlock action in the drivers door switch How do i set up the relay in the trunk
thanks in advanced
Old Jul 18, 2005 | 06:19 AM
Wiking's Avatar
thanks in advanced
...read the schema ...after Favourite Links↓↓↓↓↓↓↓↓↓
Old Jul 18, 2005 | 06:42 AM
Maxima Man's Avatar
Where do i find the schematics for the wires in the max
Old Jul 18, 2005 | 06:44 AM
Wiking's Avatar
hmmm. I'd try reading again.
Old Jul 18, 2005 | 06:52 AM
Ok so I need a relay for the trunk popper. Now with factory alarm disarm, do I just connect it or will it need a relay as well. And I don't need anything to arm the alarm?
Old Jul 18, 2005 | 06:59 AM
Wiking's Avatar
Use a relay to arm/disarm the alarm. Relay also keeps both circuits separate from each other; ensures no undesirable interference. Relay ctrl taken from u pawn shop circ...
Old Jul 18, 2005 | 07:18 AM
Maxima Man's Avatar
Ok got the wire color and location
Do i have to wire the keyless entry with the alarm in the car the alarm should arm when the doors are locked right
Old Jul 18, 2005 | 07:22 AM
Wiking's Avatar
... Do i have to wire ...
Good.
I suppose that is the best way to do. Depends if u want to employ that alarm...
Old Jul 18, 2005 | 07:26 AM
Maxima Man's Avatar
Do you think i should run wires into the door to tap into the lock unlock and then wire them back to the module
I mean is this the best way
sugestions wanted
Old Jul 18, 2005 | 07:33 AM
Wiking's Avatar
sugestions wanted
I think u can find the very same wires starting at the door lock timer module, right? Why do extra door wiring...
Old Jul 18, 2005 | 07:36 AM
Maxima Man's Avatar
Right i had not thought of that thanks that makes life a lot simpler The wires going out of the door lock timer do go straight to the drivers lock unlock button correct
Old Jul 18, 2005 | 07:37 AM
Maxima Man's Avatar
If so which wire harness leads there
Old Jul 18, 2005 | 07:45 AM
Maxima Man's Avatar
When I find the wires specified by the wire code do i just tap into those wires with the lock unlock wires coming from the keyless entry module?
Old Jul 18, 2005 | 09:01 AM
Wiking's Avatar
....the lock unlock wires coming from the keyless entry module?
I'd do that - using a separating relay.
Old Jul 18, 2005 | 10:58 AM
Maxima Man's Avatar
where does the relay come in?
Old Jul 18, 2005 | 11:07 AM
Maxima Man's Avatar
a separate relay for what?
I am sorry to inconvence you, but i know nothing about relays
Old Jul 18, 2005 | 11:24 AM
Wiking's Avatar
I'd just use it as a galvanical separator for the circuits. Read about relays, google...
Relay 85 to lock/unlok signal-/\/\-Gnd -86. This activates relay coil then closes contacts as lock/unlock is activated.
Use the contacts as input to your whatever:
1. If u need +12, connect pin 30 to fused +12V... -or- If u need gnd, connect pin 30 to gnd.
2. Your indipendent source signal 87
http://www.bcae1.com/relays.htm
Old Jul 18, 2005 | 12:25 PM
Maxima Man's Avatar
Thanks that helps alot
Old Jul 18, 2005 | 01:42 PM
Maxima Man's Avatar
Is the power coming out of the keyless entry module lock/unlock wire to low to be able to activate the lock unlock if conected to the lock /unlock wire in the max.
If it does produce enough power to activate it, do i need a relay to separate the two circuits.
Old Jul 18, 2005 | 01:43 PM
Maxima Man's Avatar
Could i not use a relay possibly
I am trying to avoid that
Old Jul 19, 2005 | 02:36 AM
Wiking's Avatar
hmm. why.
howstuffworks: http://www.howstuffworks.com/relay.htm
Old Jul 19, 2005 | 05:47 AM
Maxima Man's Avatar
So i guess you are saying the power produced by the unlock /lock wires coming out of the keyless entry is not enough to activate the 12v unlock switch in the cars electrical system.
Now i get why i need to use a relay!
Should i use one for lock and unlock separatly?
and also where is the best place to purchase relays from for a good price !
I just want the simple ones not anything fancy...
I have to try to understand whats going on in the relay!
Thanks for your help Wiking
Old Jul 19, 2005 | 06:05 AM
Wiking's Avatar
So i guess you are saying the power produced by the unlock /lock wires coming out of the keyless entry is not enough to activate the 12v unlock switch in the cars electrical system....
I dont know if those were best resources for relay edu, but good if u got it! Relays are real simpletons; but still everyone has to read once what theyre for...
I really dont know the device details youre connecting, neither the box capacity youre connecting to. But that is the beauty of using relays in aftermarket building: who cares as long as they can activate the relay. Also if/when problems arise, you have two separate entities to troubleshoot; much easier as no mixed interference is possible. (I think HERE is NO problems with the relays, but that is not so with low voltage electronics signals: you often need smtg to amplify the signal to drive a car relay.)
Make a drawing before youre connectin - helps a lot. Save the dwg... 2yrs fom now u will wonder who did what.
For relays seek the net: I know in US only autozone and radioshack, but then what do I know...
Old Jul 19, 2005 | 10:15 AM
Maxima Man's Avatar
got ya thanks
i will buy three simple relays to control lock/unlock/trunk
This will work
Old Jul 19, 2005 | 12:31 PM
Maxima Man's Avatar
I do use one relay for the lock and a separate relay for the unlock circut corect
thanks Wiking
ah2002
Mar 9, 2016 01:42 PM
flu2000
Sep 14, 2015 12:34 PM
videomano
Sep 8, 2015 03:28 PM
Hailstatejig
Sep 2, 2015 06:52 AM
