stupid *** sunroof
Old 08-18-2005, 08:45 AM
Jeff583's Avatar
stupid *** sunroof
ok please some one help, i have been ****ing with this sunroof for a couple days now and i cant figure it out, and no one on here has had the non working sunroof problem apperentially so any help is apreciated.
thanx jeff
Jeff583 is offline
Old 08-18-2005, 11:04 AM
Red89maxima's Avatar
Whats wrong with it? Won't work at all? Have you tested to see if you have power at the switch?
Red89maxima is offline
Old 08-19-2005, 04:40 PM
Jeff583's Avatar
I have torn the whole headliner down and tested every part up there by switching it with my 89s sunroof wich works and checked for power wich i have for the map lights but not for the sunroof, i followed the wires down the passenger side front windshield support and under the dash into a nest of wires, i have also tested various relays around the area under the dash but still cant seem to find any problems but i do not no exactially where the power source is so that is gonna take some tearing into the dash pretty extensively, wich seems to be my only option.
Jeff583 is offline
Old 08-19-2005, 05:08 PM
MrSector9's Avatar
If you wanted to fix it to me the easiest way is to run a 12volt wiht a relay from the keyswitch to the power supplyfor the sunroof insead of tearing into the wires really far.
There is however a circuit breaker that is directly between the batterya nd the ignition it is located right by the Fuseblock and is listed as m15 in the FSM but I am not sure if that would kill the start relay or just the sunroof power relay section (I notcied it is starter relay #2 and circuit brakers #2)
MrSector9 is offline
Old 08-20-2005, 01:48 PM
Jeff583's Avatar
i have also seen this circuit breaker on in the fsm but i cant seem to find it there is alot of **** by the fuse block, i need to find that damn circuit breaker that is most likely the problem. If anybody knows where to find it than please let me know
Jeff583 is offline
bigdogsteve
01-31-2018 04:18 PM
Fbana41
08-29-2016 12:18 PM
Forge277
06-13-2016 09:26 PM
jonreidhead
01-06-2016 09:38 AM
Vequity
09-10-2015 05:26 AM
Quick Reply: stupid *** sunroof
