problems with slave cylinder after installing new clutch
has anyone had problems with there slave cylinder after installing an upgraded clutch such as the exedy stage 1? someone told me i might have problems due to the increaed pressure.
Be sure to bleed the system completely then see if it still does it ....
you shouldn't have any problems with it unless the slave cylinder is already worn out. if the hydraulic system is in good shape, it won't be an issue. I ran the same master/slave setup for 4 years on ACT clutches before the hose finally started leaking. I replaced the slave, rebuilt the master, and installed a SS clutch line all at the same time just to get it over with.
this is gonna sound stupid but im still learning. do you need to remove the tranny to replace the slave cylinder? how can you tell if its worn? also nothing in partcular is wron just was told i might have problems in the future.
Raise and safely support the vehicle.
Disconnect and cap the hydraulic line at the slave cylinder.
Remove the nuts attaching the slave cylinder to the transmission/transaxle.
Remove the slave cylinder.
To install:
Install the slave cylinder and tighten the attaching nuts to 22-30 ft. lbs. (30-40 Nm).
Connect the clutch hydraulic line to the slave cylinder. Tighten the fitting securely.
Bleed the clutch hydraulic system.
SmokinMax02
18
09-11-2015 12:25 AM
