Lost all pressure in my clutch
Hey Everyone I need major help. I've had my car for almost 2 years and it seems like everything is going wrong recently. Today I was driving and I started a little rough in 1st gear and then my clutch started catching lower and lower. Then when I drove home from school....it was almost to the ground and then down the street from my house it wouldn't go into neutral by pushing on the clutch....lost pressure and when I would press the clutch down it stayed down and I would have to pull it up with my foot. What the heck is going on? Thanks
Maxeema
Maxeema
Originally Posted by MrGone
Check your master and slave cylinders along with the line for leaks
and i shall third it. ran into the same thing on a tacoma. turned out to be the slave cylinder. i topped off the clutch fluid, pumped (and pulled) on it for a good spell and had enough pressure to drive it home for a fix (barely).
What kind of fluid do you use for it? Is the slave cylinder right next to the brake master cylinder? A little lower and to the right of the brake booster near the firewall? I read somewhere here that it might even leak through the firewall but I couldn't find any leaks. And also where is the master cylinder if in fact that part that I am talking about is the slave cylinder. Thanks again guys
U pedal activates a pump [master cyl] to pressurize fluid. That pressurized fluid is used to work u clutch assembly, done via work cylinder. Clutch assy is between engine&gearbox...
Check Favorite Links for some info. http://www.cardomain.com/ride/748507/1
Or login to autozone.com for a online manual to figure out how it goes...
Hey guys,
I still have the problem. I filled the clutch master cylinder with brake fluid and it was really low but that didn't fix the problem. Then I tried to follow the pipe coming out of it to the slave cylinder but came to like a little box next to the transmission and didn't know if that was it or not. There was no where to fill it up with fluid. Do I have to bleed the system and if so how? The pedal still goes down completely to the floor. HELP!!! Thanks everyone!!!
Hey Guys,
I replaced the Clutch Slave Cylinder but then a week after doing that I had the same problem. I looked at the slave cylinder and it looks like there is fluid leaking from the bolt that is on the top of the slave cylinder. Do I need to change the bolt or could it be the line going to the slave cylinder? any feedback?? Thanks
smbdy has over/not tightened smtg -and/or- broken threads again = same prbl
tighten/loosen/replace/tighten until no leak
try login www.autozone.com for online haynesmanualcrap...
Hey Guys,
That bolt is the bleeder valve.....It might be loose....
Originally Posted by Cliff Clavin
I did the same thing on my first Maxima and bought some fluid at a Wal-Mart, then limped it to a place called "Clutch Doctor," since I was pretty far from home.
edit: wait..no walmart around there. now if you limped there from popeyes...
![chuckle](https://maxima.org/forums/images/smilies/chuckle.gif)
