iacv replaced
Old Sep 21, 2005 | 11:59 AM
kiyakerz's Avatar
iacv replaced
I just got done replacing my IACV. I was going to clean out the old one, but I decided I'm better off just replacing it. here is what the old one looked like
Pretty dirty... in conclusion I probably wasted my money buying a new one over cleaning the old one and now I'm left with a few questions. As I was replacing the IACV, I noticed the part on the engine where it bolted up to was pretty dirty as well. Will cleaning that out help as well? My cars idle has improved significantly, instead of being rough and moving up and down extremely, its now soft and moves up and down slightly. Also, should I use TB Cleaner or Carb Cleaner?
Old Sep 21, 2005 | 12:27 PM
MaXtUneD's Avatar
Use throttle body cleaner....
How much did the IACV run you?
Old Sep 21, 2005 | 12:44 PM
Cliff Clavin's Avatar
Way out West
Mine was far dirtier than that and I got a used one and cleaned it up really good. You basically can't clean them very well with it still on the engine. If you take it off, it will clean up nicely and improve your idle.
I use Valvoline SynPower carb, choke and throttle body cleaner:
http://www.valvoline.com/pages/produ...asp?product=52
Old Sep 21, 2005 | 04:49 PM
kiyakerz's Avatar
spent about 160 dollars on a new one.
TB cleaner... do i just spray it on the other half and put the iacv back on?
Old Sep 21, 2005 | 05:08 PM
96ItaliaSE's Avatar
il massimi bassi
160!
Old Sep 21, 2005 | 06:02 PM
Way out West
Did you get a new one?
Or, did you get a junkyard one? $160 seems like an awful lot for a junkyard one, but not enough for a new one. There are probably guys with parts cars here that would sell one for a lot less than that.
I took a pipe cleaner and TB cleaner and went to town. I tried to rinse all of the goop I loosened up with the pipe cleaner out with the blast from the TB cleaner.
Old Sep 21, 2005 | 06:37 PM
kiyakerz's Avatar
I got a new one, maybe it was 170 or 180... but no more than that. I got it from Autozone and its new not remanufactured. When I ask about cleaning it, I'm not talking about the IACV itself, I'm talking to the part you mount it to. And do you wait for the TB Cleaner to dry up once you've gotten as much crap out as you can or what? Sorry I just don't want to take a chance in messing anything up. My idle seems to be progessively be getting better since I've installed the new IACV,
Old Sep 21, 2005 | 11:19 PM
Wiking's Avatar
Wash it with justa bout any thin ner available, use brush, rag. Place it into vitrine?
Old Sep 22, 2005 | 09:48 AM
thajones's Avatar
How long did it take you to replace?
Old Sep 22, 2005 | 05:24 PM
vansskaterfreek's Avatar
where exactly is this located on my VG??
Old Sep 22, 2005 | 05:54 PM
internetautomar's Avatar
mod or sell?
by the throttle body at the front of the engine by the radiator
Old Sep 22, 2005 | 05:56 PM
Greeny's Avatar
¯\(°_o)/¯
wiking to the rescue.....You noobs need to save this guys cardomain page...
http://www.cardomain.com/ride/748507/4
PH98I30
29
Feb 10, 2025 12:03 PM
mvm062
Nov 30, 2020 09:00 AM
dvcamp
Sep 18, 2015 10:17 AM
dcam0326
Sep 8, 2015 11:02 PM
Maxima30
Sep 7, 2015 06:13 PM
