Cps
Old Oct 2, 2005 | 10:39 AM
Akuma2001's Avatar
Cps
What is the factory setting for the CPS on a VE5? I advanced the timing and made a mark , but it got erased.
Old Oct 2, 2005 | 10:47 AM
Greeny's Avatar
¯\(°_o)/¯
You need go get a timing light....that is the best way to get it back right.....
Old Oct 2, 2005 | 10:49 AM
Akuma2001's Avatar
How much does one cost?
Old Oct 2, 2005 | 10:57 AM
Greeny's Avatar
¯\(°_o)/¯
About $50 at idiotzone.....
Old Oct 2, 2005 | 11:01 AM
Akuma2001's Avatar
Are the timing on all VE5spd different? Or if I find another ve5 and copy the same postion then I will be fine?
Old Oct 2, 2005 | 11:04 AM
Greeny's Avatar
¯\(°_o)/¯
If you want to get it close Then that will work...But if you want RIGHT then get a light....
BTW...Advance auto has one for $35....Little trick, Sshhhh...buy the light, use it,keep it clean,take it back.....$$ back in your pocket....
Old Oct 2, 2005 | 11:18 AM
Akuma2001's Avatar
How does a timing gun work?
Old Oct 2, 2005 | 11:35 AM
Greeny's Avatar
¯\(°_o)/¯
craig has a writeup on his site In the how to section...
Old Oct 9, 2005 | 01:26 PM
Akuma2001's Avatar
I got a timing light and positioned it at 15deg. What's wierd is that the CPS is almost advanced all the way like on Craig's site. I have a JWT ECU. Also when it is at 15 deg. I hear a spontaneous sound from the exhaust that sounds like a small bubble flowing through some water, is that a backfire of some sort? When I retard the timing I don't hear it anymore.
Any ideas?
Old Oct 10, 2005 | 12:43 AM
Wiking's Avatar
...backfire of some sort? When I retard the timing I don't hear it anymore...
Did u read the timing marks right? CPS signal is ok - Grounding is ok?
Plug - CoilPack - ECU -condition?
Old Oct 10, 2005 | 10:11 AM
Akuma2001's Avatar
The timings marks are right. When I move around the CPS I see the timing marks move accordingly so it is probably working fine. I have a grounding kit on there and made sure all the wires are clean and tight. When I remove each plug I can hear the misfire in each coil. So probably the coil and the plug are fine. The ECU is a week old from JWT. What else could be the problem?
Old Oct 10, 2005 | 10:46 AM
Wiking's Avatar
The timings marks are right. ...
"...marks move accordingly so it is probably working fine"
- I agree. And if its signal to ECU was warped, it would do the 'misfire' all the time as the CPS itself 'does not know' anythin about ign...
- measuring supply voltages will not hurt: also take alt wires out for testing (exclude possible alt spikes -problem)
Manufacturing questions is easy:
- gas is ok?
- what is plug type & mileage & gap? (relatively easy to swap)
- why JWT ECU? Is stock ECU available (=same probl???)
Old Oct 10, 2005 | 11:01 AM
Greeny's Avatar
¯\(°_o)/¯
Agreed....Did the problem start after jwt install??...Maybe bad connection at ecu......
maxima297
Aug 3, 2015 12:50 PM
95turbo gxe
Jul 25, 2007 10:03 PM
tofor
Mar 28, 2005 10:03 AM
