possible T-belt misalignment?
Old Nov 21, 2005 | 03:47 PM
Ford5.0forlife's Avatar
First off i wanna say hello everyone im new here, now w/ pleasantries aside,
A week or 2 after buying my car i checked timing on it to find that maximum advance on it was circa 12-13 degrees btdc (between 3rd and 4th to last notch to pass the timing marker) the previous service history indicates the t-belt was done w/ a waterpump change @ 60K its at 93k now, so does this automatically mean the belt has slipped/installed wrong? if not, could i possibly correct this by taking dizzy out and reinstalling it?
Old Nov 21, 2005 | 03:49 PM
Jeff92se's Avatar
I'm needing a caw
I'm not sure if the engine would even run very well even 1 tooth off. If it runs horrid, then maybe. If it runs okay but the only thing wrong is the timing, it's probably something else.
Old Nov 21, 2005 | 04:03 PM
car runs fine, i just want to be able to bring timing to factory specs and am concerned what a missaligned dizzy or t-belt would do, any adverse affects aside from performance?
Old Nov 21, 2005 | 05:07 PM
Grace_Imports's Avatar
From my experience a VG30 will run poor even with 1 tooth off. I have had them brought to me after someone did a T-belt job and got a tooth off. If one cam tooth is out but the other isn't, then in a sense, the engine isn't in "balance" and will run crappy. I would check the dizzy first.
Old Nov 21, 2005 | 09:09 PM
maximagxe90's Avatar
the stock timing is 15 btdc,
MAXSE5SPD
Aug 23, 2015 12:06 PM
Edge
Jun 19, 2006 10:08 AM
Edge
Jun 10, 2006 07:02 AM
4dscPat
Feb 20, 2006 07:38 AM
ArcticDC5
Oct 15, 2005 10:04 PM
