Crossover placement
Old Jun 3, 2001 | 06:36 PM
Jaybird180's Avatar
Where do you guys place your passive x-overs for your component sets? Any chance of putting one in the door?
Old Jun 3, 2001 | 06:39 PM
ngthing's Avatar
just put it in your car and run wire from there to the component set.
Old Jun 3, 2001 | 06:53 PM
Jaybird180's Avatar
What I was interested in finding out is if there was any type of installation restriction, or concern with putting it in the door. Reason: I'm trial fitting w/ "inexpensive" stuff, until I 1) Get it the way I want it, and 2) Get the set I want (Thinking of Rockford Fanatic 6.5)
Old Jun 3, 2001 | 07:25 PM
ngthing's Avatar
each component set has a diff size crossover set. test fit it yourself. if it fits, then keep it there.
Old Jun 3, 2001 | 08:24 PM
DCmax's Avatar
I have a 4th gen but I had no problem putting my xovers in my front doors. The only real modification was that I wrapped them in a plastic bag to keep them from moisture.
Old Jun 4, 2001 | 06:24 AM
C-Dawg's Avatar
Yep, Plastic bag worked for me too. I would zip-tie that beotch in there, though so it doesn't move around. If you are placing it inside the area behind the door panel, make sure that it doesn't interefere with the window mechanism.
Old Jun 5, 2001 | 01:18 AM
ngthing's Avatar
there's amost NOWEHERE in the door panels to ziptie the shiet to. if you keep it in your car, you don't risk the posiblity of fuxoring your xovers from moisture or rattle damage.
Old Jun 5, 2001 | 07:26 AM
C-Dawg's Avatar
I wanted mine close to the speakers. I couldn't put them under the front seat because I have a changer under each seat (daisy chain compatible). The only other place was in the door.
Old Jun 5, 2001 | 09:57 AM
Matt93SE's Avatar
STFU n00b!
You've got several options on it..
you can mount them inside the door panels, between the panel and the door skin, or you can mount them between the door skin and the window.
You can also mount them under the dash, or behind the kick panels. just about any place is fine.. the only problem with mounting it outside the doors is that you've got to run two sets of speaker wire inside the doors. that's not an easy task.
If you can't find a place to zip-tie them in, just use hot glue and glue them to some sheet metal or plastic that won't be seen. it's strong enough to hold them in place, but soft enough to peel off if/when you decide to move things.
Old Jun 6, 2001 | 06:14 AM
C-Dawg's Avatar
That is a good idea, Matt. Mine are ziptied in between the door panels and the skin. I would have put them on the inside of the door if I would have thought about the hotglue idea. I just didn't want them banging around.
melteye
May 16, 2016 12:02 AM
vybz05
Dec 10, 2015 07:38 PM
mpbclutch33
Sep 21, 2015 01:54 PM
Adam01GXE
Mar 22, 2001 03:45 PM
The_quorum
Mar 3, 2001 10:32 PM
