Another KS question, should be easy
Old Nov 29, 2005 | 01:18 PM
eventnick's Avatar
Hello, I have a knock sensor that i bought for my 93, when i bought it i wasnt asked to specify between DOHC or SOHC i assumed they were the same but when i called the dealer earlier trying to figure out my question below they said that its a different sensor depending on DOHC vs SOHC. Im trying to sell the knocksensor as I later determined i dont need it, and i believe some one told me that the knocksensor is the same between a 3rd gen and a 4th gen....but will a knocksensor for a SOHC work in a 4th gen which are all DOHC?
Thanks Nick
Old Nov 29, 2005 | 01:25 PM
Greeny's Avatar
¯\(°_o)/¯
Yes,the K/S for the sohc/dohc 3rd gen and the 4th gen are the same...
p/n 22060-30P00
Old Nov 29, 2005 | 01:28 PM
Greeny's Avatar
¯\(°_o)/¯
btw..This info took me about 30 seconds to find in the stickies....
http://forums.maxima.org/showpost.ph...10&postcount=5
Old Nov 29, 2005 | 02:37 PM
internetautomar's Avatar
mod or sell?
hunh?
the VG (SOHC) screws into the block.
the VE and VQ use one with a hole in the middle and a bolt goes through it.
They are not the same
VG = 22060-56s10
VE and VQ=22060-30p00
Old Nov 29, 2005 | 03:32 PM
Greeny's Avatar
¯\(°_o)/¯
hunh?
VG = 22060-56s10
I got this info from your o.e parts locator sticky..in the stickies..
Old Nov 29, 2005 | 03:46 PM
mod or sell?
try pulling it up for a 91 (VG motor only) they don't list it, so I had to use some of my other sources to pull it up.
The VG motor has it's knock sensor mounted on the rear of the block by the exhaust manifold
Old Nov 29, 2005 | 03:56 PM
Greeny's Avatar
¯\(°_o)/¯
Ahhh..I am so used to using 94 as the default yr. in the idiotzone sticky...I'm a again...
Old Nov 29, 2005 | 04:18 PM
mod or sell?
94 to some = VQ
production change over in 2/94
Old Nov 30, 2005 | 01:40 PM
eventnick's Avatar
hunh?
VG = 22060-56s10
ok so i do have the 22060-30p00, thats the one that will work with the dohc 4th gens right ?
Old Nov 30, 2005 | 03:32 PM
Alex_V
Why does a VG have a knock snesor if its ignition isnt eletronicly controlled? or does it tap into the coil power and delay it?
~Alex
Old Nov 30, 2005 | 03:57 PM
mod or sell?
~Alex
something like that
Old Dec 2, 2005 | 12:10 AM
eventnick's Avatar
so yeah.... 22060-30p00 thats the 4th gen part right?
Old Dec 2, 2005 | 11:44 AM
mod or sell?
correctamundo
James92SE
142
Jan 2, 2024 09:23 AM
chisam14
Nov 6, 2018 08:56 PM
Unclejunebug
Apr 2, 2016 05:42 AM
Socalstillen
Sep 26, 2015 12:01 PM
pears
Sep 18, 2015 05:25 AM
