Rpm dipping
Rpm dipping
So i was foolign around with my amp for my subs today and i realized when i had the stereo at liek max volume the rpms would dip along with the bass hits, should i be worried about this?
Facts of life 101:
Nothing is for free. The electrical power your amps require to produce the audio must come from somewhere ................... either the alternator supplies it or the battery get drained. If you want your alternator to supply the power you need a engine management system that can detect small changes in electrical load, and as a result of that compensate for the extra engine load in order to keep the rpm constant - as it is, the designs do not cater for that so as Aaron92SE said, its to be expected.
Serious audio amps can easily chew around 50 to 100 Amp when pushed - on a 12V system like the Maxima's thats around a Kw worth of power .............. I don't have access to a typical dyno curve of a Maxima motor's performance around idle speed, but suspect the Max's motor only produce around 10Kw (if that!) at idle speed ................... so 1Kw as a percentage of that is quite significant - hence rpm drop when the control system cannot cope/compensate enough.
Replacing the batt/cap/alt will do nothing to keep the idling on the engine constant under the stated condition - in the end the same about 1Kw of power needs to be supplied by the alt for the amp if all is working as intended.
REDinLV
Aug 15, 2024 12:30 AM
ef9
Oct 4, 2015 08:43 AM
Need help
23
Oct 2, 2015 08:56 AM
