Power windows
Old Feb 4, 2006 | 12:49 PM
max89_v6's Avatar
Power windows
First off: yes, I know there's multiple problems like this posted all around the 3rd gen forum, but I wasn't able to find one like the problem I am experiencing.
I am able to roll down all of my windows from each door, except the drivers door. The drivers door will roll down the drivers window, and roll up all the other windows, but it will not roll the other three windows down. This may be due to the fact that I was cleaning my doors and dash with some cleaning solution about a week ago, so just today I pulled the window button panel out and sprayed some of it with WD-40, but no results. My exterior keypad is able to roll both passanger and driver window down, too. Any ideas???
Old Feb 4, 2006 | 12:59 PM
slickblack94's Avatar
My guess is, that you fried the master control on the drivers side.
There is alot of p/w master controls for sale on ebay and a few in here
I believe. Hope this helps some d.w.
Old Feb 4, 2006 | 02:03 PM
bhunter's Avatar
You may have damaged it first with cleaning solution, but WD-40 is DEFINITELY NOT for spraying into electrical circuits. You might be able to take it totally apart and clean it up but I doubt it. Get a new (used) master switch.
Old Feb 4, 2006 | 02:33 PM
ozzombie13's Avatar
I will eat your children
i got a spare master swith layin around. worked fine before my friend wrecked his max and junked it.
Old Feb 4, 2006 | 06:49 PM
seenoz's Avatar
clean up.
WD-40 is a good water drier but it's not good for switches. Go to Fry's or your local electronic supply store and get some electronic/PC bord cleaner.It comes in an aerosol can.
Old Feb 5, 2006 | 08:35 AM
vision90's Avatar
suo guys i have problem all my windows go down but my pf goes down only half way and it's slow to come up i hear a clunkin the door all the time so im thinking it's the regulators loose or something like that
Old Feb 5, 2006 | 08:40 AM
bhunter's Avatar
You are probably right, or it is bad.
Old Feb 5, 2006 | 09:08 AM
I'd guess the wire came off the spool,
and that will almost certainly require a new regulator.
I've replaced 3 so far in 2 different maximas.
d.w.
Old Feb 5, 2006 | 11:52 AM
internetautomar's Avatar
mod or sell?
pull the door panel and look
Old Feb 5, 2006 | 12:45 PM
max89_v6's Avatar
Do you happen to know if the whole unit is held together by adhesive, or is it possible to get to the circuits without destroying the unit?
My plans are to take it out and clean it up a little bit (today), if that's no good, then I plan on ordering a new one via ebay.
Thanks for the help! Much appreciated.
Old Feb 6, 2006 | 11:14 AM
AH11980's Avatar
Power windows slow to come up
hey people , my 1991 Maxima has a small glitch , the passenger side windows both front and back are slow to come up. They go down easy its the coming up part thats tough. the back on even stopsat one point. Do i need to change the regulators or just lube them up or something. Thanks in advance
P.S if i want to post a new thread what do i need to do?(donate?)
Old Feb 6, 2006 | 11:20 AM
bhunter's Avatar
It will all come apart with screws and unsnapping. Go over to Carroll radio supply on 6th street and get some electronics spray cleaner.
Old Feb 6, 2006 | 11:26 AM
bhunter's Avatar
You can start a thread after 15 posts. In your case it sounds like maybe you are losing a motor or you need lubed. Take off your door panel and inspect/lube the regulators. Lube the cable guides and the track. If the guides and cables all look OK and the lubing doesn't help you may need a motor.
Old Feb 6, 2006 | 05:03 PM
AH11980's Avatar
Motors hmmm..
k thanks for the info. so you are saying i should try to lube them up, what should i use ? and how much is a motor in worst case scenario?
thanks again
Old Feb 6, 2006 | 05:38 PM
mod or sell?
window motors or regulators:
http://internetautomart.com/maxima/3rdgen/window.html
have you pulled your door panel yet?
Old Feb 6, 2006 | 06:09 PM
AH11980's Avatar
nope
nope, but i will this weekend wanna try lubing it up first. im checking your site ou as we speak
Old Feb 7, 2006 | 08:07 AM
jewsonlot's Avatar
if you pull your switch appart watch out for all the rockers, there all on spings and they have a mind of there own.
Old Feb 15, 2006 | 01:24 PM
bearone2's Avatar
if you still have the switch let me know what you want for it.
Old Feb 15, 2006 | 04:27 PM
ozzombie13's Avatar
hows $15 shipped sound? offer what u think
Old Feb 15, 2006 | 07:09 PM
bearone2's Avatar
reasonable but a couple questions.
i've got a 93se and the controller is on the door.
are these all the same switch if they're on the door? does one fit all?
how to pay?
thanks
TallTom
57
Oct 14, 2025 05:16 PM
gigabyte
Jan 6, 2017 06:05 PM
Fbana41
Aug 29, 2016 12:18 PM
sliptap
Sep 30, 2015 05:57 AM
