Intake's the name of the game
Old Mar 8, 2006 | 09:34 PM
  #41
itsjustmeZ's Avatar
as far as a cai i just dropped the bottom off my air box semmes the same as a cai in the engine comp.as far as getting rid of the resonator ive heard mixed comments ont that and power losses and gains.
Old Mar 9, 2006 | 04:54 AM
  #42
jkmay01's Avatar
Lil 8
not to sound short, but how can you get the same effects as a CAI by just removing the bottom of your air box? the best thing that you will get from this is more of a growl, no HP increase. , and you wont be intaking cold air just hot ambient air from the radiator, and engine. Nothing CAI in that set up. If you check some of the CAI install guides like, Warpspeed you will see the difference
Old Mar 9, 2006 | 05:01 AM
  #43
kcidmil's Avatar
Originally Posted by HTPerformance
Remove the plastic pipe, you'll need something hot like a soldering iron or something, or a hacksaw to remove the big box from the pipe. Inside there is a small 1-2" hole that you can cover over with a piece of plastic from what you just removed and epoxy it on. An alternative is to just replace the pipe with some metal pipe, but this is cheaper.
And actually better unless you have a 4" metal pipe. The stock tube is 4", and most aftermarket pieces are 3" mandrel.
Old Mar 9, 2006 | 05:06 AM
  #44
kcidmil's Avatar
Here's a video clip of my intake, Ractiv filter w/ 3" mandrel pipe. The top end of the RPM range just makes me
http://www.gregg-henry.com/video/intake%20009.asf
Old Mar 9, 2006 | 09:06 AM
  #45
heresmymind
ok so the resignator is the plastic thing that the tub connects to. so i cut that off. and plug it. what do i do with the tube?
Old Mar 9, 2006 | 10:50 AM
  #46
Phoenix's Avatar
Lives in a Maxima
We need to go a little more in depth here...
Ok, so the resonator is that big plastic thing that hangs off the flex portion of tube between the TB and the MAF... right? Concerning removing it, what purpose does it serve being there? I always thought it was for moisture collection or something.
Does anyone have a pic of an intake sans resonator? I'm a little confused on how you're "plugging up" the hole where the resonator was.
Old Mar 9, 2006 | 11:01 AM
  #47
Jeff92se's Avatar
I'm needing a caw
Cripes. Take flexy mid pipe off w/ resonator. Uugly plastic blob. You might have to remove some bolts, I forget. Loosen clamp that holds resonator. Remove resonator assembly. Plug the hole that's left with a cap from a rattle spray paint can. DONE
Old Mar 9, 2006 | 12:35 PM
  #48
heresmymind
i have a vg engine. wheni looked at the flex pipe the box was un removable. i dont wanna go cutting away without knowing how its connected/the holes on the inside of the pipe
Old Mar 9, 2006 | 12:36 PM
  #49
Jeff92se's Avatar
I'm needing a caw
Then just leave it. Won't do anything for performance.
Old Mar 9, 2006 | 01:45 PM
  #50
PunkFriday's Avatar
Power Dorifto Extraordinaire!
i have the warpspeed y-pipe and 2-1/2" exhaust into a hi-flow muffler. my intake is currently having the finishing touches put on, but i have a short aluminum tube going straight to the sensor to a cone. i made my own heat shielding, but now my intake is facing the wrong direction. derrr.
Old Mar 14, 2006 | 11:54 PM
  #51
Loco7's Avatar
if anyone is interested in a CAI for a 91-93 accord in a black finish, which will work for a 3rd gen Max, I'll sell it for what i paid $37. there is nothing wrong with it the diameter is about a inch smaller than the one i have i just wanted it since it is one piece. i did notice a small decrease in power compared to what i have already only had it on for about maybe a hours worth of driving time. so if anyone's interested email me. this is a pic of just the pipe
Old Mar 15, 2006 | 09:07 PM
  #52
Dillbag's Avatar
Suprise butsechs!!!
So loco7, are you saying that the accord intake felt like it had less power, or just the one you had that was a samller diameter, than the one currently on the car?
Old Mar 16, 2006 | 08:30 AM
  #53
terryg911's Avatar
I added a KN Filter that just fit into the stock box. It helped some in performance, but the MPG dropped by about 1MPG. Would it have been better to get a cone filter or some adapter so that the stock box os replaced by a filter. 91 Maxima SE
Old Mar 16, 2006 | 12:20 PM
  #54
Loco7's Avatar
what i am saying is i have a CAI for my car that is i think 5" and this one i bought for the accord is 3" and on acceleration it doesn't feel like i have as much punch compared to what i had with the 5" CAI. but it don't feel stock either way and it still sound good. although i think the 5" has a better roar but that's my opinion!
Old Mar 16, 2006 | 12:31 PM
  #55
Maxima Man's Avatar
Where Did You Get Your 5 Inch Intake From?
Old Mar 16, 2006 | 11:18 PM
  #56
Loco7's Avatar
can't lie it was on the car when i bought it (bought from a friend) he got it from a friend that at the time owned a small import shop and as for him ?????
aw11power
Oct 10, 2021 04:57 AM
JonBlz
Oct 5, 2015 06:02 PM
maxima297
Sep 30, 2015 03:32 PM
09maxshawn11
Sep 30, 2015 10:28 AM
MichMaxFan
Sep 30, 2015 09:18 AM
