engine missing
Old May 3, 2006 | 03:58 PM
ozzombie13's Avatar
I will eat your children
engine missing
the car feels like it is only running on 4 cyl. i called a friend at a shop and he said the wiring harness is a problem on these cars. so i think it could be in the injector wiring harness near the plug. or maybe one of the injectors. but im not sure. what is the best way to get the injector harness plug off of the the injector? the injector itself should ohm out from 10-14 right? gas is just too damn expensive to waste. HELP! please
Old May 3, 2006 | 05:57 PM
ozzombie13's Avatar
i just found that if i wiggle the plug at the injector then it gets better or worse. has anyone changed the plugs that go to the injector? how far back should the wiring be replaced?
Old May 3, 2006 | 06:13 PM
Greeny's Avatar
¯\(°_o)/¯
Clean all the harnesses/poles with a wire brush....
Old May 3, 2006 | 07:23 PM
vansskaterfreek's Avatar
yo ozz.. i just remembered, i have a set of VE injectors.. but i think they are different from VG injectors.. but hell, if they work, ill sell them cheap..
Old May 3, 2006 | 07:28 PM
ozzombie13's Avatar
ok well i guess i will try and see if they will work, as i stated earlire thought the problem seems to be more with the wires in the harness than the injectors
Old May 4, 2006 | 05:45 AM
Greeny's Avatar
¯\(°_o)/¯
Ve/vg injectors don't mix dude...They are different...
Old May 4, 2006 | 05:56 AM
synoptic's Avatar
Have you checked to make sure all the cylinders are firing, check the spark plugs etc?
Old May 4, 2006 | 07:15 AM
ozzombie13's Avatar
the harness definatly has a problem at the injector plug. so i need to find a way to fix the harness. has anyone else done this?
Old May 4, 2006 | 11:45 AM
ozzombie13's Avatar
the injector at the messed up plug also goes from 12-130 when i try to ohm it. it keeps changing. i am confused. would this be why the car seems to run on and then falls on its face at other times
Old May 4, 2006 | 03:00 PM
internetautomar's Avatar
mod or sell?
how dirty is the connector?
Old May 4, 2006 | 04:30 PM
ozzombie13's Avatar
it is all green on both sides of the connector. and where the wires go into the top of it. the problem is that the wires are loose going into the connector
Old May 4, 2006 | 07:10 PM
mod or sell?
the connector on the injector and the harness are both green?
you can TRY to scrape them clean with a metal dental pick, but if it's a bad as it sounds you'll probably need to replace both the injector and connector.
I'd personally also inspect ALL the injectors and their connectors
Old May 5, 2006 | 03:59 PM
ozzombie13's Avatar
i took some electrical component cleaner and sprayed the connector and injector. used some little screw drivers to scrape it a little. then i split the cover on the wires and wrapped them seperatly and then together in electrical tape. its better, but i still think i need to replace the injector.
Old May 5, 2006 | 04:06 PM
Scope's Avatar
Im izz sexay
Did you grease the connectors using electrical grease? I've never heard of wiring harnesses being a problem on these cars though but I know the injectors are either a hit or a miss in most cases. DO NOT use injector cleaner these injectors seems to have some sort of allergy to them.
Old May 5, 2006 | 04:59 PM
ozzombie13's Avatar
i didnt use any elec. grease. what about sea foming the car? i have heard that works fairly well. i have also heard to stay away from the in the tank injuctor cleaners.
Old May 5, 2006 | 05:05 PM
Scope's Avatar
Im izz sexay
Sea foam may work if there's some gunk in there. Just add it in gradually unless you want to see what your car does when a fluid like this enters all at one time.
Old May 5, 2006 | 05:06 PM
Pervis Anathema's Avatar
Did you file a police report?
Old May 5, 2006 | 05:28 PM
Scope's Avatar
Im izz sexay
For what??????
Old May 5, 2006 | 05:52 PM
For what??????
Well if the engine is missing....
Old May 5, 2006 | 06:09 PM
Greeny's Avatar
¯\(°_o)/¯
Hehe..I thought the same thing when i first seen the thread title..
Old May 6, 2006 | 05:58 AM
yo oz... if you want a harness for the injectors, ive got some.. take all you ned, the car is getting junked soon..... well it was supposed to be about 3 months ago....
Old May 6, 2006 | 06:13 AM
Scope's Avatar
Im izz sexay
I am madd slow. lol
conansriver
Nov 18, 2015 02:46 PM
dcam0326
Sep 18, 2015 04:52 PM
seesole
Sep 14, 2015 12:38 PM
ballerchris510
Sep 11, 2015 05:29 PM
A32goldylocks
Sep 2, 2015 06:39 AM
