trunk help!
Old Jun 16, 2001 | 06:12 PM
dnas420's Avatar
i was wondering if someone knows how to find out why i cant pop the trunk from inside the car from the latch by the driver seat. is there a cable broken you think. how do i go about fixing or looking into this problem? please help!
Old Jun 16, 2001 | 06:55 PM
Mr. Nismo's Avatar
There are two things you should check. 1.)There is a cable that opens the trunk, it might be broken or may need an adjustment. 2.)The latch that opens the trunk is broken. Check it and let me know what happens.
Old Jun 16, 2001 | 07:37 PM
dnas420's Avatar
ummm
i know where the latch is. and it opens the gas tank so i am guessing that the latch isnt broken. but where is the cable?? under the car, under the carpet, inside the trunk?
Old Jun 16, 2001 | 09:07 PM
flyry110's Avatar
oh damn, that sux, mine's electric, but my lock on my trunk doesn't work, so if that ever quits i'm screwed!
Old Jun 16, 2001 | 11:15 PM
dnas420's Avatar
well
technically my trunk lock is going bad also. hope i can fix my cable before my key doesnt work anymore.
Old Jun 17, 2001 | 12:37 AM
Mr. Nismo's Avatar
Re: ummm
What you should do is work backwards. Start with the trunk and trace the cable to the front. One good idea is to lock the trunk when is open. Then go to the front and release the latch to see if it unlocks it. I believe that 89-91 Maxes you had to pull to open the trunk and push to open the gas door. The cable runs from the drivers floor to the trunk but you have to look under the carpet to trace it. I had a 90 Max so it's been a while. I know for sure that it has to be the cable or the latch/hook that locks the trunk. Let me get to 89-91 Max and I will let you know. Hopefully some of the info I provided will help you. I'm just trying to give you some hints.
Old Jun 17, 2001 | 10:16 PM
ray89se's Avatar
lock out switch
there is a lockout latch in the trunk just under the lock catch it in the middle of the catch near the back wall
it there is so when u valet park the car no one will get in to your trunk with out the key .... i have this feature set cause i want the theifs to have a hard time trying to steal the junk from the trunk
REDinLV
Aug 15, 2024 12:30 AM
mrgooch
Sep 21, 2015 08:43 PM
lux97Max
Sep 14, 2015 07:07 PM
Mikes14Max
Advance Paint and Body Work
Sep 14, 2015 05:28 PM
rbaker100
Sep 6, 2015 02:46 PM
