daytime running lights 4 Canada
Old May 5, 2006 | 07:28 PM
dandidit
Hey All!
My 92 GXE is cursed with Daytime Running Lights that come on as soon as you start the car. I think they use the high beam filament in the bulbs, maybe at a reduced voltage?? My problem - only 1 works, but it's not a bad bulb. High and low beam headlights work fine.
My local grease monkey said something about a DRL control module, but he didn't know much about it.
Can anyone give me any hints on this? Where is this module located? Or can I disable them completely? (will the headlights still work if the module is removed?)
Old May 6, 2006 | 03:24 PM
Greeny's Avatar
¯\(°_o)/¯
I would just unplug it and see if all your regular lights still work ok..
Old May 7, 2006 | 07:40 AM
AH11980's Avatar
im in canada too
hey waasup, i have a us model 3rd gen. they didnt have drl in it so i went to a garage and they installed thme for me, its actually two relays they put it, one on each headlight. i went to the nissan dealer and he told me the actual OEM module is 350$ and two hours of work to fish all the wires around. My suggestion would be to take your car to a shop where they do car alarms installs. Or if you want go to canadian tire , they sell a module for 25$ . if you gonna install it yourself you need to connect the two headlights together , because the headlights in the nissans have individual relays. What happend to you is probably one of these realys either died or you have a bad connection from your DRL module to the headlights (sorry i dont know where the module is placed in the car, i could check for you). I cant think of anything more for now.
P.S I got mine done at Duro , it took the tech 25 minutes to install them , they work great and he used relays for the drl. hope it helps you somewhat, oh and yes if you unplug the module your headlihghts will work.the module is just so that your lights come on as soon as you turn your key thats all
Old May 15, 2006 | 12:01 PM
RyderMax's Avatar
Had the same problem - a new DRL from Nissan Canada cost me $100CDN, and it took me 15 minss to install.
What happened in mine was that the relays were shorting out, and finally gave up - they were sticking or not making contact...
Michael
Old May 15, 2006 | 01:01 PM
MrSector9's Avatar
weird... my car dont have DRL and i am in canada.
I dont think either of them have DRLS
Old May 15, 2006 | 06:40 PM
VEvolution's Avatar
I miss my VE
So which of the lights are used for the DRLs? Headlights?
Old May 15, 2006 | 06:51 PM
cachejob's Avatar
from what i understand the DRLs are the high beams running at 40%. my DRL/headlights in general have been acting up too. was hoping for a way to circumvent the module completely, but i might have to start phoning around to the wreckers.
Old May 16, 2006 | 07:38 PM
RyderMax's Avatar
The power for 1 highbeam is powered through a relay that feeds both highbeams.
In the end, buying new was simplest. If you're buying a 15 yo DRL module to replace your own 15 yo DRL module, where are you going to be in 6 months?
Had a friend with an SUV that was pulled over by the police for flashing lights at oncoming traffic, giving away a speed trap. He said he wasn't - and when he was out of the vehicle, the lights started flashing again. Same problem - DRL module fried. Lucky for him the cop saw it...
Old May 16, 2006 | 09:02 PM
VEvolution's Avatar
I miss my VE
Hehe, people still do that? Thats classic! You won't find that here in NY.
Old May 19, 2006 | 10:49 AM
cachejob's Avatar
RyderMax can you tell me how to get ahold of Nissan Canada to get the DRL module for $100 Canadian? just got off the phone with Nissan Victoria and they want $226 for it... i found one at a wreckers for $75, but like you said, who knows how long it would be good for. thanks in advance.
Old May 30, 2006 | 08:58 AM
cachejob's Avatar
bttt. hoping for a response from RyderMax. i would send an email, but none listed...
Old May 30, 2006 | 09:32 AM
Greeny's Avatar
¯\(°_o)/¯
Try this maybe??
http://www.automotiveelectronicacces...aeapn480hd.htm
Old May 30, 2006 | 11:24 AM
cachejob's Avatar
thanks for the link. looks interesting and the price is right... has anyone used one of these in their max?
Old Jun 11, 2006 | 04:13 PM
RyderMax's Avatar
Sorry for not being there
Life got busy - what can I say.
I got my DRL unit 'off the shelf' at Abbotsford Nissan. No muss, no fuss. Chilliwack Nissan didn't have one available, and I seem to recall they wanted an extra $10 or so...
Old Jun 13, 2006 | 09:28 AM
cachejob's Avatar
thanks RyderMax, guess i need to get back on the phone again. i'll hardwire the lights in myself before i pay $226 for the module. hopefully i can find one closer to $100.
tsi6001
Oct 3, 2022 10:23 PM
ah2002
Mar 9, 2016 01:42 PM
Jeffesernia11
Aug 23, 2015 06:09 PM
Viralkill
Aug 17, 2015 10:54 AM
Viralkill
Aug 16, 2015 05:09 PM
