Positive cable
Old Jun 17, 2006 | 02:59 PM
MAXI's Avatar
Positive cable
does the main positive wire connects directly from the battery to the starter?
i'm asking coz i would like to replace my corroded battery clamp and i would like to replace the cable/wire too.
thanks.
Old Jun 17, 2006 | 08:46 PM
Governor's Avatar
Posative wire always goes to the starter solenoid;;
Old Jun 18, 2006 | 12:17 AM
Scope's Avatar
Im izz sexay
thanks.
Why are you replacing the wire? You really don't need to unless you are upgrading your amp. IMO too much trouble for no gains. The clamp you can either clean or replace but it isn't that much trouble either way. Wires don't go bad like that as they are usually sealed pretty good and unless you see any tears or burns they'll go for much longer than the life of the car. If you want to do some upgrading to your wires do The Big Three. Add another positive wire to alternator with a 100 amp fuse near the battery. Do another ground to chassis and another chassis to engine. Or you can contact Matt93se and buy one of his grounding kits. Either way upgrading your grounds is a better choice IMO. Most poor charging problems do come from corroded grounds not hot leads.
gigabyte
Jan 6, 2017 06:05 PM
sliptap
Sep 30, 2015 05:57 AM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
