Digi climate control problems
Old Jun 19, 2006 | 04:23 PM
KeithD's Avatar
Well both my clock and digi climate control are starting to perform the disappearing act on me, and whacks on the dash are only gonna last so long. I know there are some wonderful writeups for the clock, but i was wondering if anyone has repaired the climate control with successful results? Any help would be appreciated!
Old Jun 19, 2006 | 08:46 PM
mszilves's Avatar
My '92 SE Auto Climate control just started doing the same thing... out of the blue, a couple of days ago, the display just started to go on/off. I'd also like to know if anyone has any advice on how to fix it?
Old Jun 21, 2006 | 02:27 PM
marke's Avatar
DITTO for me!
Anybody have any ideas, short of buying another one?
Old Jun 21, 2006 | 10:01 PM
Alex_V
touch up the solder joints you can access. All of them. Nissans solder sucks for durability.
~Alex
Old Jun 22, 2006 | 04:36 PM
PovCityHustla's Avatar
My manual climate control is screwed up too. The temprature **** (cold-hot selector) is stuck on cold. Before it got stuck, it only happned occasionally, now its totaly stuck on cold. Any help at all or a direction to a link would be a great help!
Old Jun 22, 2006 | 04:52 PM
Greeny's Avatar
¯\(°_o)/¯
Here is a few old threads on the digi control...
http://forums.maxima.org/showthread....te+control+fix
Old Jun 22, 2006 | 05:54 PM
marke's Avatar
thanks for the threads,
when do I get to search?
Old Jun 22, 2006 | 05:57 PM
Greeny's Avatar
¯\(°_o)/¯
When you do this---->http://forums.maxima.org/payments.php
Old Jun 22, 2006 | 06:06 PM
marke's Avatar
ah, yes of course
I'll have to check into that
Old Jun 22, 2006 | 06:30 PM
internetautomar's Avatar
mod or sell?
you can try to lube it up, but chances are it won't help.
BTW the control head is the same for ALL 3rd gens with manual climate control.
it is a pain to take out
Old Jun 22, 2006 | 08:47 PM
mszilves's Avatar
Thanks for the great info, will try this out and let u all know the results.
Old Jun 23, 2006 | 03:45 AM
Will's Avatar
KeithD, we are relatively close distance-wise. I do have extra clocks and climate control units that work. Let me know if you want to replace yours with a used one and I can help with ther removal and install.
Old Jun 26, 2006 | 04:50 PM
mrkanda's Avatar
Taking my Maxima to the Max!
Hello, same problem -- fading/faded display. Still seems to work OK though. Wonder if it will get worse and affect the performance.
Old Jun 26, 2006 | 05:04 PM
Will's Avatar
It won't affect the performance, it's just a nuisance not knowing what you set your temp at.
Old Jun 27, 2006 | 12:36 AM
How do i lube it up? Sorry if i sound stupid. I havent done many things like this before. I was going to spray some lube in the little grove but i thought that might ruin the electronics on the inside..
DJLAX152
May 4, 2021 11:46 AM
Mar 12, 2020 12:06 AM
Starrider
Dec 18, 2015 04:43 AM
slowlifer
Sep 8, 2015 05:53 AM
