Cam Angle Sensor Testing
Old Jun 24, 2006 | 01:22 PM
92 Max's Avatar
I'm having an ongoing, intermintant problem with my 92 SE. It gets a flat spot sometimes when coasting or turning a 90 degree turn. The engine loses power, then catches again. It will do this on a very occasional basis, I can't make it do it again after it does it if I try to do the same thing. I thought it might be the cam angle sensor, so I pulled it and tested it. When I tested the "A" connector, per the FSM, the voltage goes from 0 to 5 V per spec. When I check the "B" connector voltage, as the sensor is rotated, it goes from 0.09V to 5V. Is this normal? Or is the non-zero reading indicative of a bad sensor?
matts95max
Apr 23, 2025 10:44 AM
gustavison
Oct 4, 2015 06:50 PM
Max139617
Sep 29, 2015 06:44 PM
ac max 92
Sep 17, 2015 07:35 AM
conansriver
Sep 11, 2015 10:26 AM
