Rear caliper and rotor capatability 90 to 94.
Old Jun 29, 2006 | 05:48 PM
goon9's Avatar
I'm trying to order the right rotors.
I have a 90 maxima.
I bought 94 rear calipers.
89 to 90 part numbers for rotors are different than 91 to 94.
Will my new calipers not work?
Or am I cool if I buy 94 rotors?
Old Jun 29, 2006 | 07:18 PM
internetautomar's Avatar
mod or sell?
did you buy loaded calipers with the bracket?
Old Jun 29, 2006 | 08:00 PM
Alex_V
triplegmax is going through the same thing. The 91+ calipers are bigger and the older wont bolt up (I sold him a 90 caliper months ago) I guess the rotors are diffrent too. PM him and see if he hasnt bought the right caliper yet you guys might be able to trade.
~Alex
Old Jun 30, 2006 | 03:41 AM
goon9's Avatar
Yes, caliper with bracket.
Old Jun 30, 2006 | 06:36 AM
DigitalMaxima90's Avatar
not meaning to jack your thread or anything but. how can i add rear disc brakes to my 1990 GXE. It has drums n once i get some wheels that drum is gonna ruin the looks.
Old Jun 30, 2006 | 06:49 AM
tripleGmax's Avatar
calipers were changed 9/90 according to mizereeX
hey if you need the pass side...ill send it to you, just pay me shipping. with the bracket and bolts. send me an email at gregg@gregg-henry.com and i can give you my cell number. im hardly ever on aim anymore.
Old Jun 30, 2006 | 07:21 AM
xavier27's Avatar
is it possible to change rear drums to discs? is it even worth the trouble?
Old Jun 30, 2006 | 08:05 AM
Mizeree_X's Avatar
Getting back to his roots
Yes, read the stickies, there is a conversion writeup somewhere in there.
Old Jun 30, 2006 | 10:37 AM
mod or sell?
the earlier bracket that went to the strut (flat piece of metal) is different than the later one.
ROTOR
Note: rear; solid disc; w/ rear disc; sedan; from 9/1989 to 8/1990; overall dia.: 258.0; min thick: 9.0; height: 45.0
ROTOR
Note: rear; solid disc; w/ rear disc; sedan; from 9/1990; overall dia.: 258.0; min thick: 8.0; height: 44.5
if you switch the rotor to match the caliper it may work, but I'm pretty sure the caliper will end up being spaced too far out and would have a better fit from an 86 Z31 (I think that's the deal)
a search on rear Z31 BBK will give you more info
Old Jun 30, 2006 | 03:44 PM
goon9's Avatar
BBK will be much later on. Your right though. I got the newer rotor with the newer caliper and it's too spaced out. I'm just going to ga back to the salvage yard and get the newer strut bracket. Bummer. Good little lesson to learn.
Old Oct 10, 2006 | 11:41 AM
traxtar944's Avatar
Would be lost w/out the org
Sorry to open a 4 month old thread...but isn't putting post 90 calipers on an 89-90 hub assembly and bracket the same thing as a BBK? After reading info on them, is seems that the rear BBK kit is essentially the same as putting 89-90 rear caliper brackets on 91-94 calipers, then using Z31 rotors. Correct??
Old Oct 10, 2006 | 01:44 PM
goon9's Avatar
Not sure about the z31 rotors fitting. I didn't pursue it because I think my wheels are too small.
I think it might work.
Old Oct 10, 2006 | 01:54 PM
89blackse's Avatar
"and falling like a rock"
our rear brakes suck. its a 3rd gen fact.
Old Oct 10, 2006 | 01:58 PM
goon9's Avatar
After replacing everything, they're tight. No maintenance kills them.
Old Oct 10, 2006 | 02:01 PM
89blackse's Avatar
I replaced the rear calipers, rotors, pads, and bleed the brakes (all 4 ends) and I still cant tell a difference in rear braking power.
Old Oct 10, 2006 | 02:20 PM
goon9's Avatar
Did you break em in?>
Old Oct 10, 2006 | 02:25 PM
89blackse's Avatar
i did the 40 to 5mph, then 2x 60 to 5mph runs, then a 60 to 0 mph with out standing on the brakes to avoid imprinting them.
If thats what you mean...
Old Oct 10, 2006 | 05:02 PM
goon9's Avatar
Yeah, I used the ebake to help cut it a little better.
Old Oct 10, 2006 | 06:22 PM
mod or sell?
the Z31 rotor BBK fits under the stock 92-94 SE wheels just fine.
Old Oct 11, 2006 | 03:45 PM
goon9's Avatar
I have 99 se's
I was dead certian the bleeder wouldn't clear.
Old Oct 11, 2006 | 03:53 PM
traxtar944's Avatar
the stock 92-94 sawblades won't fit over the front BBK though, right? Thats a 13" rotor plus z32 caliper. I can't imagine there to be enough clerance.
Old Oct 11, 2006 | 04:41 PM
mod or sell?
Z31 is REAR BBK.
Front rotor stock maxima 280mm
Rear rotor stock maxima 258mm
1987 300Z rear rotor 282mm
matts95max
Apr 23, 2025 10:44 AM
BkGreen97
Apr 2, 2016 05:47 AM
flu2000
Sep 8, 2015 02:23 PM
crazyespn
Sep 3, 2015 01:30 PM
A32goldylocks
Sep 2, 2015 06:39 AM
